OlaFlow solver running error
Like Tree2Likes
  • 1 Post By Wakatsuki
  • 1 Post By Phicau
Old   October 1, 2020, 15:31
Default OlaFlow solver running error
Wakatsuki is on a distinguished road
Hi, I am using olaflow solver for the simulation of overtopping of vertical seawall, everything looks fine after I setFields, However, when I typed 'olaflow' to run the simulation, this error kept appearing, I have tried many methods, but the progress was very limited.
Create time
Create mesh for time = 0
Selecting dynamicFvMesh staticFvMesh
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Reading field porosityIndex
Porosity NOT activated
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.00595238
Time = 0.00595238
MULES: Solving for alpha.water
alpha.water BC on patch inlet
Phase-1 volume fraction = 0.278097 Min(alpha.water) = 0 Max(alpha.water) = 1
#0 Foam::error printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam DICPreconditioner::calcReciprocalD(Foam::Field<dou ble>&, Foam::lduMatrix const&) at ??:?
#4 Foam DICPreconditioner DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#5 Foam::lduMatrix preconditioner::addsymMatrixConstructorToTable<Foa m DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#6 Foam::lduMatrix preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:?
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/boapink/OpenFOAM/boapink-7/platforms/linux64GccDPInt32Opt/bin/olaFlow"
#10 Foam::fvMatrix<double>::solve() in "/home/boapink/OpenFOAM/boapink-7/platforms/linux64GccDPInt32Opt/bin/olaFlow"
#11 ? in "/home/boapink/OpenFOAM/boapink-7/platforms/linux64GccDPInt32Opt/bin/olaFlow"
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13 ? in "/home/boapink/OpenFOAM/boapink-7/platforms/linux64GccDPInt32Opt/bin/olaFlow"
Floating point exception (core dumped)
Rosy likes this.
Wakatsuki is offline   Reply With Quote
Old   August 16, 2021, 04:52
Rosangela
Rosy is on a distinguished road
Hello Wakatsuki,
when I type 'olaflow' to run the simulation, I have a similar error. How did you solve this?
Rosy is offline   Reply With Quote
Old   August 16, 2021, 20:36
Pablo Higuera
Phicau is on a distinguished road
Hi Both,
there is a floating point error (sigFpe - division by 0) when solving the pressure Poisson equation. Probably this is due to a bad mesh or choosing incorrect boundary conditions, but there are other possibilities.
If you started your case from an olaFlow tutorial, I would suggest that you revert the changes that you have made, one by one, until you find which one leads to this error.
Best,
Pablo
Rosy likes this.
Check out my new project: olaFlow --> The olaFlow Support Thread
Phicau is offline   Reply With Quote
Old   August 17, 2021, 04:39
Default OlaFlow running problem
Rosangela
Hi Pablo,
thanks for your quick reply.
As you suggested, I started my case from an OlaFlow tutorial, editing the appropriate files. I want to model two vertical rigid cylinders partially submerged in water and subject to wave motion (solitary wave). Wanting to implement the model in 3D, I started from the IRREGTANK tutorial, modifying BlockMeshDict, adding two cylinders drawn in Salome, providing a mesh with SnappyHexMeshDict. Being new to Openfoam, unfortunately I can't understand where the mistake is, because my case doesn't work. Some modified files are attached. I would be really grateful if you agreed to help me.
File Type: txt setFieldsDict.txt (1,015 Bytes, 1 views)
Old   August 17, 2021, 20:19
Pablo Higuera
Hi Rosy,
As I mentioned it is an issue with the pressure boundary conditions. You cannot simply specify zero gradient, it needs to be fixedFluxPressure, the same as the other walls already defined in the file.
I would suggest that you spend some time learning from the tutorials and trying simple 2D cases before getting into more complex cases.
Best,
Pablo
olaflow solver
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
