October 27, 2020, 08:29 |
Compressible turbulent channel flow
Rozie
Rep Power: 6 |
I am trying to simulate a wall-bounded compressible channel flow (M=2) using sonicFoam. I set synthetic turbulent generator at the inlet, however my result does not show turbulent velocity near the wall and its rather laminar. my inlet boundary condition is turbulentInlet with 10% intensity and the outlet is inletOutlet. The result is like following: Anyone has a clue what could be wrong with my simulation?
October 27, 2020, 10:51 |
Rep Power: 7 |
would do you mean by turbulent velocites? The velocity at the wall is zero since you apply a noSlip boundary condition. It looks like what I would expect. |
October 27, 2020, 11:06 |
#3 | |
Rozie
Rep Power: 6 |
In the literature, the DNS of compressible channel flow has many fluctuations near the wall. I am deploying WM-LES though. |
October 27, 2020, 12:15 |
Rep Power: 7 |
Didnt know you are trying to do an LES. I dont know a WM-LES Model. As far as I know only Smagorinsky and WALE are implemented in OpenFOAM. And if you are using a LES model with a sub grid scale viscosity, you have to make sure, that your mesh is fine enaugh to resolve the big eddies.
Also, if there is no boundary seperation, I dont know where turbulence should come from. Has the pipe some sort of roughness? How does your synthetic turbulence work? Is it like a pseudo random number generator? |
October 27, 2020, 12:41 |
#5 | |
Rozie
Rep Power: 6 |
The mesh should be good for at least some larger eddies. No, I have plane walls and just generation artificial turbulence at the inlet which is similar to a tutorial case in incompressible\pimpleFoam\channel. replicating the tutorial case for incompressible case, it shows the eddies. However for my compressible case I only get the mean velocity. Here is what the literature shows for compressible channel flow, the near wall is highly turbulent. But I do not know how realistic would be having turbulent region near wall like this. |
Validation: Turbulent Channel Flow, pisoFoam, LES | Xiaoyu Yang | OpenFOAM Running, Solving & CFD | 23 | December 19, 2019 11:51 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
How to get fully developed turbulent flow in a channel | TQIM | STAR-CCM+ | 2 | November 25, 2012 22:37 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 17:23 |
