EHD model very low deltaT
Old   November 3, 2020, 04:56
Default EHD model very low deltaT
X
mcfdma is on a distinguished road
I am working on an electrohydrodynamics (EHD) model and have issues with deltaT.
http://openfoamwiki.net/index.php/Co...ectromagnetics
EHDFoam
With the same setup, for lower electrical conductivity \sigma, my solver works fine with deltaT in order of 1e-8. However, when I use a different fluid which has higher electrical conductivity (and because of that need to choose a lower flow rate = low Ux), the detlaT is in the order of 1e-77.
Could anyone guide how I can bring deltaT back to normal???
I am including a small section of log file using GAMG solver if useful:
PIMPLE: iteration 1
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.0005588225373  Min(alpha.water) = -1.524317027e-22  Max(alpha.water) = 1.000000002
DICPCG:  Solving for Ue, Initial residual = 1.943188846e-08, Final residual = 9.980163579e-15, No Iterations 588
DILUPBiCG:  Solving for rhoE, Initial residual = 1.376162146e-08, Final residual = 1.4447631e-16, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 0.002436202718, Final residual = 0.0001215341975, No Iterations 500
time step continuity errors : sum local = 1.383292408e-10, global = -6.663405978e-12, cumulative = -1.59258934e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0009382469796, Final residual = 4.607140964e-05, No Iterations 534
time step continuity errors : sum local = 6.036468106e-11, global = 2.420807244e-12, cumulative = -1.592565132e-07
GAMGPCG:  Solving for p_rgh, Initial residual = 0.0001156991252, Final residual = 2.222468915e-05, No Iterations 20
time step continuity errors : sum local = 2.734996283e-11, global = -1.46125281e-13, cumulative = -1.592566593e-07
ExecutionTime = 34059.05 s  ClockTime = 34214 s
Courant Number mean: 3.397615704e-05 max: 0.3118083742
Interface Courant Number mean: 2.751246388e-07 max: 0.03718473623
deltaT = 4.329599813e-77
Time = 1.2329e-05
My controlDict:
application     interFoam;
startFrom       latestTime;
stopAt          endTime;
endTime         0.2;
deltaT          1e-05;
writeControl    adjustableRunTime;
writeInterval   0.02;
purgeWrite      0;
writeFormat     ascii;
writePrecision  10;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.3;
maxAlphaCo      0.2;
maxDeltaT       1;
My fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
//    grad
divSchemes
    div(rho*phi,U)   Gauss upwind;
    div(phi,rhoE)    Gauss upwind;
    div(phi,alpha)   Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
    div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
//    laplacian(eps,Ue) Gauss SuperBee corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
    rhoE;
My fvSolution:
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        cAlpha          1;
       // MULESCorr       yes;
       // nLimiterIter    3;
       // solver          smoothSolver;
       // smoother        symGaussSeidel;
       // tolerance       1e-8;
       // relTol          0;
    pcorr
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       0.001;
            relTol          0;
            smoother        GaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration false;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels     1;
        tolerance       0.0001;
        relTol          0;
        maxIter         100;
        pcorrFinal
        solver          PCG;
        preconditioner
            tolerance       0.001;
            relTol          0;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       0.0001;
        relTol          0;
        maxIter         100;
    p_rgh
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.05;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    p_rghFinal
        solver          PCG;
        preconditioner
            tolerance       1e-08;
            relTol          0;
            nVcycles        2;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-08;
        relTol          0;
        maxIter         20;
    U
        tolerance       1e-06;
        relTol          0;
        nSweeps         1;
    Ue
        solver		 PCG;
        preconditioner   DIC;
        tolerance        1e-14;
        relTol           0.0;
    UeFinal
        solver		 PCG;
        preconditioner   DIC;
        tolerance        1e-14;
        relTol           0.0;
    rhoE
        solver		 PBiCG;
        preconditioner   DILU;
        tolerance        1e-14;
        relTol           0.000;
    rhoEFinal
        solver		 PBiCG;
        tolerance        1e-14;
        relTol           0.000;
    "(k|B|nuTilda)"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nCorrectors     3;
    nNonOrthogonalCorrectors 0;
    nAlphaCorr      1;
    nAlphaSubCycles 3;
    cAlpha          1;
    pRefPoint      (0 5e-5 1e-5);
    pRefValue      0;
I am running this case on parallel but did not have issues while running it for lower conductivity.
Similarly, I tried using PCG solver in fvSolution but similar deltaT : 1e-81
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        cAlpha          1;
       // MULESCorr       yes;
       // nLimiterIter    3;
       // tolerance       1e-8;
       // relTol          0;
     "pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-5;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-07;
        relTol          0.05;
    p_rghFinal
        $p_rgh;
        relTol          0;
    U
        tolerance       1e-06;
        relTol          0;
        nSweeps         1;
    Ue
        solver		 PCG;
        preconditioner   DIC;
        tolerance        1e-14;
        relTol           0.0;
    UeFinal
        solver		 PCG;
        preconditioner   DIC;
        tolerance        1e-14;
        relTol           0.0;
    rhoE
        solver		 PBiCG;
        tolerance        1e-14;
        relTol           0.000;
    rhoEFinal
        solver		 PBiCG;
        tolerance        1e-14;
        relTol           0.000;
    "(k|B|nuTilda)"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    nCorrectors     3;
    nAlphaCorr      1;
    nAlphaSubCycles 3;
    cAlpha          1;
    pRefValue      0;
mcfdma is offline   Reply With Quote
Old   November 3, 2020, 05:46
X
2D axisymmetric case and these are my boundary conditions:
alpha
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    axis
        type            empty;
    inlet
        type            fixedValue;
        value           uniform 1;
    nozzleWalls
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    domainWall
        type            zeroGradient;
    floor
        type            zeroGradient;
    front
        type            wedge;
    back
        type            wedge;
p_rgh
dimensions      [1 -1 -2 0 0 0 0];
boundaryField
    inlet
        type            zeroGradient;
    nozzleWalls
        type            zeroGradient;
    atmosphere
         type           totalPressure;
        p0              uniform 0;
    domainWall
        type            totalPressure;
        p0              uniform 0;
    floor
        type            zeroGradient;
    axis
        type            empty;
    front
        type            wedge;
    back
        type            wedge;
rhoE
dimensions      [0 -3 1 0 0 1 0];
boundaryField
    inlet
        type            zeroGradient;
    nozzleWalls
        type            zeroGradient;
    atmosphere
        type            zeroGradient;
    }domainWall
        type            zeroGradient;
    floor
        type            zeroGradient;
    axis
        type            empty;
    front
        type            wedge;
    back
        type            wedge;
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type		fixedValue;
        value		uniform (0.00194 0 0);
    nozzleWalls
        type            fixedValue;
        value           uniform (0 0 0);
    atmosphere
        type            zeroGradient;
    domainWall
        type            zeroGradient;
    floor
        type            zeroGradient;
    axis
        type            empty;
    front
        type            wedge;
    back
        type            wedge;
Ue
dimensions      [1 2 -3 0 0 -1 0];
boundaryField
    inlet
        type            zeroGradient;
    nozzleWalls
       type            fixedValue;
        value           uniform 4500;
    atmosphere
        type            zeroGradient;
    domainWall
        type            zeroGradient;
    floor
        type            fixedValue;
        value           uniform 0;
    axis
        type            empty;
    front
        type            wedge;
    back
        type            wedge;
ehd, ehdfoam, electrohydrodynamic, electrospray
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
[OpenFOAM-2.1.0] kklOmega RAS Turbulence Model (low Re) alquimista OpenFOAM Running, Solving & CFD 64 June 17, 2016 14:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Enhanced wall treatment, low re k-e model, k-w model with low Re correction junz FLUENT 0 April 21, 2015 15:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
