Mapped boundary condition mass flow rate behavior |
August 4, 2020, 10:05 |
Rep Power: 7 |
Dear Foamers,
I am working on a case where I have to use a smaller geometry by achieving fully developed condition at the inlet (due to its complexity simulating a bigger geometry takes way too long)... To do so, I imposed the following boundary condition on U: Code:
outlet { type zeroGradient; value uniform (0 0 0); } inlet { type mapped; interpolationScheme cell; value uniform (0 0 -0.4021); setAverage false; } Here is my main question: So I made a change and imposed "setAverage" as follows: Code:
outlet { type zeroGradient; value uniform (0 0 0); } inlet { type mapped; interpolationScheme cell; value uniform (0 0 -0.4021); setAverage true; average (0 0 -0.4021); } Cheers, MJ |
September 18, 2020, 02:52 |
Ran Yi
Rep Power: 6 |
Hi MJ,
1. What is your inlet setting in polyMesh/boundary? 2. What does your geometry look like? I noticed the velocity in Z-direction is negative. BTW, have you solved this issue? Best, Ran |
November 5, 2020, 10:32 |
#3 | |
Rep Power: 7 |
Hi Ran, Thanks a lot for the reply and please accept my apologies for responding rather late... 1. The inlet boundary type is "patch" 2. It is a vertical geometry (in z-direction) where the fluid enters the domain from the bottom. Unfortunately I cannot share the geometry I really appreciate your thoughts on this. Regards, MJ |
November 5, 2020, 11:35 |
Adhiraj
Rep Power: 15 |
When I use this boundary condition I have to set the inlet boundary type to
mappedPatch. This is in OpenFOAM 2.3.1. Here is an example from my constant/polyMesh/boundary file: Code:
inAir { type mappedPatch; inGroups 1(mappedPatch); nFaces 16000; startFace 16759500; sampleMode nearestCell; sampleRegion region0; samplePatch none; offsetMode uniform; offset (0 0 0.04); } |
November 5, 2020, 13:57 |
#5 | |
Rep Power: 7 |
Thank you very much for your prompt response. I tried this with OpenFOAM 1812 and (unfoirtunately) "mappedPatch" is not recognized as a valid boundary condition: Code:
--> FOAM FATAL IO ERROR: Unknown patchField type mappedPatch for patch type mappedPatch MJ |
chtmultiregionsimplefoam, mapped, mass flow rate, openfoam 1812 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
