Inviscid compressible flow using rhoSimpleFoam |
November 12, 2020, 04:19 |
ishan
Rep Power: 8 |
Hello.
Is it possible to setup inviscid compressible simulation using rhoSimpleFoam ? I made the following changes to my setup to setup an inviscid case:
I have looked in the posts here but could not get complete information. Can someone please tell me should I make any more changes ? |
November 12, 2020, 05:02 |
ishan
Rep Power: 8 |
Wouldn't setting of Sutherland coefficients to 0 do the job ?
November 12, 2020, 07:36 |
ishan
Rep Power: 8 |
I am running right now the case with the above mentioned conditions(mu set to 1e-9, Pr = 0.85) and I am noticing that the pressure in the system is not being updated.
It has been only 9 iterations but shouldn't the pressure also be calculated ? I am monitoring the pressure and the velocity at the outlet patch(where mass flow rate is imposed) and while the velocity changes, the pressure doesn't. The pressure value is the same with which it was initialized. Not sure what is going wrong. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
rhoSimpleFoam with specified mass flow rate at outlet | ishan_ae | OpenFOAM Running, Solving & CFD | 3 | September 1, 2020 01:11 |
VOF compressible two-phase flow | lzhaok6 | Fluent Multiphase | 0 | August 17, 2020 17:17 |
[rhoCentralFoam] simulating compressible inviscid flow | Yuval | OpenFOAM Running, Solving & CFD | 2 | January 27, 2016 21:33 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
