Thin Walls using blockMesh
Old   June 16, 2008, 08:50
Default Hi I want to create a thin
Varun Vikas
varun is on a distinguished road
Hi
I want to create a thin wall in OpenFOAM using block Mesh utility. Actually, my problem is similar to supersonic flow over two thin flat plates aligned horizonatlly and separated by a vertical distance say h.
----> --------PLATE 1---------
----> --------PLATE 2---------
How can I create a emsh with thin walls using blockMesh?
Varun
varun is offline   Reply With Quote
Old   June 16, 2008, 09:17
Default Hi Varun! Just define a wal
Assistant Moderator
Bernhard Gschaider
Hi Varun!
Just define a wall patch that contains the border between two blocks (that should be the plate) TWICE, just change the order of the points. That way you will have the wall "look" into both blocks (which is what you want, if I understand you correctly)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 3, 2008, 11:13
Default Hi Bernard! It seems not to
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Bernard!
It seems not to work!
I'm doing as you said, but blockMesh tells me:
Default patch type set to empty
Trying to specify a boundary face 4(1 8 10 5) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 4 named Wall.#0 Foam::error::printStack(Foam:stream&) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<foam::word> const&, bool) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/blockMesh"
#4 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/blockMesh"
#5 main in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/blockMesh"
#6 __libc_start_main in "/lib64/libc.so.6"
#7 __gxx_personality_v0 in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/blockMesh"
From function polyMesh::polyMesh
const IOobject& io,
const pointField& points,
const cellShapeList& cellsAsShapes,
const faceListList& boundaryFaces,
const wordList& boundaryPatchTypes,
const wordList& boundaryPatchNames,
const word& defaultBoundaryPatchType
What's wrong?
Bye, Ivan
ivan_cozza is offline   Reply With Quote
Old   October 8, 2008, 12:38
Default Hi Ivan! you have to define
Assistant Moderator
Bernhard Gschaider
Hi Ivan!
you have to define the "wall" twice. Once as a patch of the "upper" and once as a patch of the "lower" block. Did you do that?
Bernhard
Old   October 9, 2008, 08:16
Default I triyed both defining one pat
Ivan Flaminio Cozza
I triyed both defining one patch with both of the sides, and two separate wall patch, it don't works!
I catch something with createBaffles, but the results are very bad!!!
Old   May 4, 2009, 14:33
Default same issue
Jon Singer
jpsinger is on a distinguished road
I am getting the same error on blockmesh word for word (I cannot paste the txt as I ssh in sorry) with a similar scenario (I am trying to make a simulated fan). I am fairly new to all this so forgive me if I am missing something basic. I tried:
patches
wall top
(1 9 14 6)
wall bottom
(14 6 1 9)
and:
patches
wall internal
(1 9 14 6)
(14 6 1 9)
What is it I am missing?
Thanks,
Jon
jpsinger is offline   Reply With Quote
Old   December 8, 2020, 13:18
Default Similar problem
Fortunato Neto
Forbraer is on a distinguished road
Hello everyone, i'm troubles. Having a similar problem. I trying to model a vertical thin plate, to make some dsmcFoam simulations. But, using this blockmeshDict i'm not having sucess.
vertices
(-5 0 0) // 0
(0 0 0) // 1
(0 10 0) // 2
(-5 10 0) // 3
(-5 0 36) // 4
(0 0 36) // 5
(0 10 36) // 6
(-5 10 36)// 7
(-5 0 18) // 8
(0 0 18) // 9
(0 10 18) // 10
(-5 10 18)// 11
(20 0 36) // 12
(20 10 36)// 13
(20 0 18) // 14
(20 10 18)// 15
(20 0 0) // 16
(20 10 0) // 17
(0 0 0) // 18 -1
(0 0 18) // 19 -9
(0 10 18) // 20 -10
(0 10 0) // 21 -2
blocks
hex (0 1 2 3 8 9 10 11) (10 36 36) simpleGrading (1 1 1) // Block 1
hex (8 9 10 11 4 5 6 7) (10 36 36) simpleGrading (1 1 1) // Block 2
//hex (1 16 17 2 9 14 15 10) (40 36 36) simpleGrading (1 1 1) // Block 3
//hex (9 14 15 10 5 12 13 6) (40 36 36) simpleGrading (1 1 1) // Block 4
hex (18 16 17 21 19 14 15 20) (40 36 36) simpleGrading (1 1 1) // Block 3
hex (19 14 15 20 5 12 13 6) (40 36 36) simpleGrading (1 1 1) // Block 4
boundary
flow
type patch;
faces
(4 5 6 7)
(5 12 13 6)
(0 8 11 3)
(8 4 7 11)
(3 11 10 2)
(11 7 6 10)
(6 13 15 20)
(21 20 15 17)
(0 8 9 1)
(8 4 5 9)
(18 19 14 16)
(19 5 12 14)
(12 13 15 14)
(14 15 17 16)
plan1
type symmetryPlane;
faces
(0 1 2 3)
plan2
type symmetryPlane;
faces
(18 16 17 21)
walls1
type wall;
faces
(2 10 9 1)
walls2
type wall;
faces
(18 19 20 21)
The problem starts running but, stops in "particles inserted" and no longer runs.
Santos Dumont - Father of Aviation
Forbraer is offline   Reply With Quote
Use wall function on some walls (not all walls) Mahdi10 FLUENT 1 February 16, 2009 11:52
shell conduction @ thin walls Jiri Beran FLUENT 0 May 18, 2008 14:08
[blockMesh] BC with blockMesh ville OpenFOAM Meshing & Mesh Conversion 1 December 4, 2006 05:11
How to define thin walls in Gambit or Fluent? Meenu FLUENT 1 March 23, 2006 15:30
Thin Walls in CFX5 Dave Hargreaves Main CFD Forum 1 April 14, 1999 12:08
