December 13, 2020, 16:08 |
How to couple solvers
Mehdi Go
Rep Power: 5 |
Dear Foamers,
I'm working on a case with a multiphase flow (I'm using compressibleInterFoam to solve it). I want to add to it the resolution of heat transfer in a solid (Thick Wall). I'm now imposing a temperature at the wall, but I want in the next step to model the heat transfer between the wall and the fluid. For this, I suppose that coupling compressibleInterFoam and exchanging the wall temperature calculated with chtMultiRegionFoam would be enough. I couldn't find on litterature a way to exhange these informations between solvers. Is there anyone that can suggest help on it, please. I would be glad to exchange with you and give you further information, such as files and case. Regards, |
December 13, 2020, 17:10 |
Chris Harding
Rep Power: 9 |
Although not a perfect match, Dr. Trushar B. Gohil has an example that is similar to what you want to do. After selecting Facebook Beginning OpenFOAM link, select reference [1], and look under programming module. He combines the scalar transport equation to various solvers. References: Harding, Chris. (2020, August). A List Of Modules And Parts: Dr. Trushar B. Gohil Training. URL: https://www.facebook.com/notes/begin...0920165720923/ |
December 13, 2020, 17:37 |
Mehdi Go
Rep Power: 5 |
Thank you for your answer. The Openfoam.com version there is the chtMultiRegionTwoPhaseEulerFoam solver which can handle this type of problems. The only inconevnient is that is uses an Euler-Euler approach for the fluid region. From my tests, the Euler-Euler approach doesn't catch the interface as good as the VOF approach. I have some few problems with using openfoam.com in my computer also.
December 13, 2020, 17:38 |
#5 | |
Mehdi Go
Rep Power: 5 |
March 16, 2021, 04:48 |
Hello
#6 | |
John Kim
Rep Power: 5 |
Thank you John |
coupling 2 solvers, heat boundary condition, heat transfer, multiphase boundary wall |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
How to couple two solvers for simulation of two regions? | jianglong | OpenFOAM | 4 | November 4, 2021 12:06 |
Couple two solvers in OpenFOAM | nuttita | OpenFOAM Programming & Development | 2 | October 4, 2018 04:34 |
FSI solvers - best solvers | steven123 | OpenFOAM Running, Solving & CFD | 0 | July 8, 2014 10:26 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
