Velocity Source Not Working
Old   January 11, 2021, 12:39
Default Velocity Source Not Working
Corey
trahancj is on a distinguished road
Hello, i am new to OF, and I have been able to run all the examples, but I am having a problem getting any dynamics out of a case I have created where I have a 2D closed domain and a
momentumSource
type meanVelocityForce;
selectionMode all;
fields (U);
Ubar (10.0 0 0);
I am getting residuals = 0 for all times and no movement. My thinking is that this should simulate a surface stress.
My other files are as follows:
fvSolution ::
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 0;
relTol 0.1;
smoother GaussSeidel;
pFinal
$p;
smoother DICGaussSeidel;
tolerance 1e-06;
relTol 0;
"(U|k|nuTilda)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-05;
relTol 0.1;
"(U|k|nuTilda)Final"
$U;
tolerance 1e-05;
relTol 0;
PIMPLE
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 1001;
pRefValue 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 2;
pRefCell 0;
pRefValue 0;
fvScheme:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
div(phi,k) Gauss limitedLinear 1;
div(phi,B) Gauss limitedLinear 1;
div(B) Gauss linear;
div(phi,nuTilda) Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
controlDic:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application pimpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 1000;
deltaT 10.;
writeControl timeStep;
writeInterval 200;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
fieldAverage1
type fieldAverage;
libs (fieldFunctionObjects);
writeControl writeTime;
fields
U
mean on;
prime2Mean on;
base time;
p
mean on;
prime2Mean on;
base time;
Any help is greatly appreciated!
trahancj is offline   Reply With Quote
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
