RAS Model
Old   February 10, 2021, 12:23
Default RAS Model
Gonçalo Ramos Nobre
gonsanobre is on a distinguished road
Im doing a two mixing flow on intermixingfoam , it is a RAS model but when it runs, didn't solve any iteration and tells me that initial residual to pcorr is 0 and the final residual is 0 to...
I already searched a lot about this error but i couldn't be able to solve it, here is what the log file says :
No finite volume options present
GAMG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
I would be greatful if someone could help me.
Thank you
gonsanobre is offline   Reply With Quote
Old   February 10, 2021, 15:27
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Still difficult to diagnose the matter.
Could you please provide sufficient detail for us to understand your problem?
HPE is offline   Reply With Quote
Old   February 11, 2021, 13:44
Gonçalo Ramos Nobre
Ok it was resolved by using wall functions on Epsilon Kappa and nut variables, i think the problem was that because of not using wall functions on boundary conditions, it was having trouble solving the equations of k-e and nut ,
Thank you a lot for the reply!!!
intermixingfoam, ras
totalFlowRateAdvectiveDiffusive BC with RAS Model EMM OpenFOAM Running, Solving & CFD 1 April 25, 2019 05:45
Vof and RAS Model Mousa.h OpenFOAM Running, Solving & CFD 0 May 12, 2018 03:20
[OpenFOAM-2.1.0] kklOmega RAS Turbulence Model (low Re) alquimista OpenFOAM Running, Solving & CFD 64 June 17, 2016 14:39
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" musabai OpenFOAM Running, Solving & CFD 2 February 20, 2015 14:07
change RAS model Jackie Chen OpenFOAM 2 February 26, 2014 05:14
