February 9, 2021, 06:41 |
Farfield BCs for wing in free flow
Jamie MacLeod
Rep Power: 6 |
I have a simulation of an M6 wing, that is having trouble with the farfield boundary. The farfield is hemispherical, with a symmetry plane.
At the inlet side of the hemisphere, the pressure is significantly lower than it should, but velocity is more or less what it should be. However after the lower pressure, the velocity surrounding the wing is lower than it should be. Currently the BCs are freestreamVelocity (Vinf = 39.93) and freestreamPressure (Pinf = 101353). In various 2D sims I've done around aerofoils, these BCs have worked perfectly well, so I'm really confused why they aren't giving a good BC for this 3D sim. My best guess is something about it interacting with the symmetry plane, but that still doesn't help me fix the issue. Any help is much appreciated! |
February 11, 2021, 11:02 |
Jamie MacLeod
Rep Power: 6 |
So this was simply a very trivial mistake...
I put the vertical velocity component in the y-direction, not the z-direction. This made it seem like it was coming out of the symmetry plane, and caused the anomaly. Works perfectly fine when in the correct axis. |
boundary condition error, buoyanboussinesqsimple, simplefoam |
3D Fan:Calculation of induced flow rate by fan rotation at free delivery | Catthan | FLUENT | 3 | November 6, 2013 05:19 |
Multi phase flow VS Free surface flow | Kiffer | Main CFD Forum | 0 | November 17, 2012 00:17 |
Mass flow BCs and Pressure differential BC | CFDLife | CFX | 5 | January 26, 2009 07:14 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
BCs of Free convection flow | Polly | CFX | 0 | February 4, 2003 04:25 |
