Getting max number of iterations exceeded problem in komegasst turbulence model |
March 24, 2022, 06:32 |
Chaitanya kishore
Rep Power: 4 |
When running the solver in laminar case, it is running.
But after turning on the turbulence model komegasst, I am getting maximum iterations exceed: 100 in the second iteration itself. in file /home/ubuntu/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 70 Energy -> temperature conversion failed to converge: --> FOAM FATAL ERROR: Maximum number of iterations exceeded: 100 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
