Adding viscous dissipation term to energy equation
Like Tree1Likes
  • 1 Post By hjasak
Old   August 25, 2006, 07:27
Default Hi, I am interested in imp
newbee
I am interested in implementing the viscous heat dissipation term laplacian(mu,U) in the following energy equation:
solve
fvm::div(phi, T)
- fvm::laplacian(alphaEff, T)
- S*q/(rho*Cp) (<-source term)
- fvm::laplacian(mu, U) (dissipation term)
I am a beginner at openFoam so the question might be basic for some on this sight, sorry.
anyway. when trying to compile this the following error message starts like:
SOURCE_DIR=.
SOURCE=hSimpleFoam.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/erik/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels -I/home/erik/OpenFOAM/OpenFOAM-1.3/src/transportModels -I/home/erik/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/hSimpleFoam.o
TT.H: In function 'int main(int, char**)':
TT.H:40: error: no match for 'operator-' in 'Foam::operator-(const Foam::tmp<foam::fvmatrix<type> >&, const Foam::tmp<foam::geometricfield<type,> >&) [with Type = double](((const Foam::tmp<foam::geometricfield<double,> >&)((const Foam::tmp<foam::geometricfield<double,> >*)(& Foam::operator/(const Foam::tmp<foam::geometricfield<type,> >&, const Foam::dimensioned<double>&) [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::dimensioned<double>&)((const Foam::dimensioned<double>*)(& Foam::operator*(const Foam::dimensioned<double>&, const Foam
Does anyone know what I am doing wrong
/Thanks Erik
Old   August 25, 2006, 07:41
Default Nope, not like that: what you
Hrvoje Jasak
Nope, not like that: what you are trying to do here is to add a laplacian with U as a working variable into the equation for temperature. Does not make sense
It is basically something like (adjust for compressible fluid etc):
volTensorField gradU = fvc::grad(U);
the term you want is something like
(mu_l*(gradU + gradU.T()) && gradU)
This lot appears as the source in the energy equation.
Enjoy,
Hrv
Hrvoje Jasak
Old   August 25, 2006, 09:56
Default thank you for your answer!
newbee
Im working on a incompressible flow (modification of simpleFoam) so I guess i dont need to adjust your formula.
I have two question on the suggested source term.
what is mu_|?
what is gradU.T()?
my case is a channel with hydraulic diameter of 53mm and 11 meters long. The channel is for an air flow of 20 m/s(approx incompressible). im hoping this extra term will rise the temperature 5 more degrees so that my simulation fits experimental data.
Thanks again
/Erik
Old   August 25, 2006, 11:08
Default mu_l is laminar viscosity. gr
Hrvoje Jasak
mu_l is laminar viscosity. gradU.T() would be a transpose of the gradU tensor. For incompressible flows, you can just do mu_l*magSqr(gradU), that should do the trick. Don't forget to add turbulence dissipation (epsilon) to the energy blance.
Hrv
Aaron_L likes this.
Hrvoje Jasak
Old   August 25, 2006, 14:33
Default Thank you once again, another
newbee
another novice question follows I am afraid.
How is epsilon to be added and do you know where I can find ducumentation of this so I can have som sort of theoretical backupp for my thesis work.
This formula was no ploblem to add to the energy equation but I wouldent expect you to be surpriced either.
/Erik
Old   January 17, 2018, 11:56
A. Min
alimea is on a distinguished road
Enjoy,
Hrv
Hi
I also want to add viscous dissipation to energy eqn. but my fluid is not Newtonian and has a special stress tensor. So the work of stress tensor field is "tau && grad(U)"
1- is it a correct relation for work of stress tensor field? or I should write:
tau && [grad(U) + transpose of (grad(U))]
2- is it correct to write:
solve
fvm::div(phi, T)
- tau && grad(U)
thank you
alimea is offline   Reply With Quote
Old   March 3, 2021, 10:37
anthony761 is on a distinguished road
I think now, it can just be enabled in fvOption with
dissiapation1
    type            viscousDissipation;
    selectionMode   cellSet;
    cellSet         sourceCells1;
see: https://www.openfoam.com/documentati...ssipation.html
anthony761 is offline   Reply With Quote
Source term in energy equation macdidi CFX 15 May 9, 2017 20:23
Bouyancy term in Energy equation CFDtoy Main CFD Forum 2 August 4, 2008 11:04
Mass transfer Term in Mixture Energy Equation CFDtoy Main CFD Forum 0 July 3, 2008 16:14
Is the viscous dissipation term fully included? yann Phoenics 0 June 5, 2003 10:23
How to deal with this energy equation source term? H.S.Fang FLUENT 2 December 27, 2001 06:42
