3 phase multiphaseInterFoam
Old   February 23, 2018, 04:28
Default 3 phase multiphaseInterFoam
kaaja is on a distinguished road
I am trying to simulate flow around a (boat like) object in stratified waters.
Fluids: air, fresh water and salt water.
Dimensionality: 2D.
Solver: multiphaseInterFoam.
The result does not look good:
For U I get some kind of wake infront of the object:
The phases look like
The above is not what I expected.
I have run two other scenarios.
The 2nd scenario is two phases with air and salt water.
For U I then get
For alphas I get
Comparing the two above scenarios, we see that the last scenario get a more reasonable velocity profile infront of the object.
Finally, I have run a 2-phase case between fresh water and salt water.
For alpha I then get
Comparing the last picture with the corresponding 3-phase picture, we see that there is a big difference in alpha distribution. In the last case we get a nice internal wave.
I cannot figure out why the 3-phase simulations give such bad results. It seems like openFoam and multiphaseInterFoam (which is used in all scenarios) can handle different combinations of two fluids well, but everything blows up when combing all fluids together in the 3-phase simulation.
In the next post I will add the BC-files for the 3-phase simulation.
kaaja is offline   Reply With Quote
Old   February 23, 2018, 04:42
Continuation from previous post:
Some files:
alpha.air
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;//1;
boundaryField
    //- Set patchGroups for constraint patches
    #includeEtc "caseDicts/setConstraintTypes"
    inlet
        type            fixedValue;
        value           $internalField;//uniform 1;//
    outlet
        //type            zeroGradient;
        type            variableHeightFlowRate;
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 1;//$internalField;
        value           uniform 1;//$internalField;
    barge
        type            zeroGradient;
alpha.freshWater
internalField   uniform 1;
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;//uniform 0;//
    outlet
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;//$internalField;
        value           uniform 0;//$internalField;
    barge
        type            zeroGradient;
alpha.saltWater
boundaryField
    inlet
        type            fixedValue;
    outlet
        lowerBound      0;
        upperBound      1;
    atmosphere
        type            inletOutlet;
        inletValue      $internalField;//uniform 0;
    barge
        type            zeroGradient;
U
Umean 0.24;
mUmean -0.24;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform ($mUmean 0 0);
boundaryField
    inlet
        type            fixedValue;
    outlet
        type            outletPhaseMeanVelocity;
        alpha           alpha.saltWater;
        Umean           $Umean;
    atmosphere
        type                pressureInletOutletVelocity;
        tangentialVelocity     $internalField;
        value                 $internalField;//uniform (0 0 0);
    barge
        type            movingWallVelocity;
        value           uniform (0 0 0);
prgh
dimensions      [1 -1 -2 0 0 0 0];
boundaryField
    inlet
        type            fixedFluxPressure;
    outlet
        type            zeroGradient;
        //type            fixedFluxPressure;
        //value           $internalField;
    atmosphere
        type            totalPressure;
        p0              uniform 0;
    barge
fvSolutions
solvers
    /*"alpha.*"
        nAlphaSubCycles 4;
        cAlpha          1;
    "alpha.*"
        nAlphaCorr      1;
        nAlphaSubCycles 2;
        cAlpha          1;
        icAlpha         0; //from dtcHull
        MULESCorr       yes;
        nLimiterIter    10;
        alphaApplyPrevCorr  yes;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
        minIter         1;
    "pcorr.*"
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-05;
            relTol          0;
            smoother        GaussSeidel;
        tolerance       1e-05;
        relTol          0;
        maxIter         100;
    p_rgh
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.05;
    p_rghFinal
        solver          PCG;
        preconditioner
            tolerance       1e-07;
            relTol          0;
            nVcycles        2;
        tolerance       1e-07;
        relTol          0;
        maxIter         20;
    "pcorr.*"
        solver          PCG;
        //preconditioner  DIC;
        preconditioner
            tolerance       1e-5;
            relTol          0;
        tolerance       1e-5;
        relTol          0;
    p_rgh
        //solver          PCG;
        solver          GAMG;
        smoother        DIC;
        tolerance       1e-07;
        //relTol          0.05;
        relTol          0.01;
        //absTol 0;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|k|omega).*"
        tolerance       1e-08;
        relTol          0.1;
        nSweeps         1;
    "(U|k|omega).*"
        nSweeps         1;
        tolerance       1e-06;
        relTol          0.1;
        minIter         1;
    UFinal
        $U;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
PIMPLE
    momentumPredictor   no;//yes;
    nOuterCorrectors    1;
    nCorrectors         3;
relaxationFactors
    equations
        "U.*"           1;
relaxationFactors
    equations
        //p_rgh 0.5;
        //U 0.5;
        ".*" 1;
cache
    grad(U);
fvSchemes
ddtSchemes
    default         Euler;//localEuler;
gradSchemes
    default         Gauss linear;
    limitedGrad     cellLimited Gauss linear 1;
divSchemes
    div(rhoPhi,U)  Gauss linearUpwind grad(U);
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss linear;
    div(phi,k)      Gauss upwind;
    div(phi,omega) Gauss upwind;
    //div(phi,k)      Gauss linearUpwind limitedGrad;
    //div(phi,epsilon)  Gauss linearUpwind limitedGrad;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    //laplacian(diffusivity,cellMotionU) Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
setFieldsDict
defaultFieldValues
    volScalarFieldValue alpha.air 0
    volScalarFieldValue alpha.freshWater 1
    volScalarFieldValue alpha.saltWater 0
regions
    boxToCell
        box (-120 0 0) (20 40 200);
        fieldValues
            volScalarFieldValue alpha.freshWater 0
            volScalarFieldValue alpha.air 1
    boxToCell
        box (-120 0 -100) (20 40 -0.2);
        fieldValues
            volScalarFieldValue alpha.saltWater 1
    boxToFace
        fieldValues
    boxToFace
        fieldValues
Among several other things, I have tried:
- Refining mesh
- Increase nAlphaSubsycles
- Increase alphaCorr
- Decrease deltaT
- Change maxCo and maxAlphaCo
- Change the phase used in the outlet BC for U (Results become even worse if alpha.fresh water is used here)
- Increase size of mesh
As a side note, the two-phase solutions, which I have simulated with multiphaseInterFoam, is also simulated with interFOam, giving similar results.
Any help will be very appreciated!
Old   March 1, 2018, 03:14
Paul Palladium
Fauster is on a distinguished road
I would model the salt water using a passive transport scalar and not a dedicated phase. When you use interfoam solver you assume that phases are non miscible. This not the case between salt water and fresh water.
For example if you want to model the dispersion of smoke in air from a chimney output you will use a passive scalar to track the smoke concentration.
Fauster
Fauster is offline   Reply With Quote
Old   March 23, 2018, 01:20
Fauster
Thank you very much for responding to this, Fauster!
Is this what twoLiquidMixingFoam does?
Old   March 6, 2021, 12:33
Reviewer #2
randolph is on a distinguished road
Here may be your solution
interFoam with scalar transport in single phase
Thanks,
Rdf
randolph is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 02:08
iteration questions in discrete phase iknowjesus FLUENT 4 March 13, 2015 06:07
Phase segregation in multiphaseInterFoam Tracker OpenFOAM 3 May 7, 2010 04:10
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
