particleCount 0/no particles injected: icoUncoupledKinematicParcelFoam
Old   February 28, 2021, 05:04
Default particleCount 0/no particles injected: icoUncoupledKinematicParcelFoam
anonymous
particlecount_0 is on a distinguished road
I am having a problem with the icoUncoupledKinematicParcelFoam solver. I am using a simple 3d Geometry of a square with a side length of 0.2m. Inside the square is a small obstacle. The mesh has about 160000 points. The left side of the square is my inlet and the right side my outlet. For generating the U-field needed for the icoUncoupledKinematicParcelFoam solver I used the simpleFoam solver. I have used different velocity boundary conditions ranging from 0.02m/s to 0.0002m/s. Up until now everything works fine.
When I am running the icoUncoupledKinematicParcelFoam solver I get now error messages but the particlecount stays 0, even though I should have injected particles. All generated cloud_properties files read:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "0.5/uniform/lagrangian/kinematicCloud";
    object      cloudProperties;
processor0
    particleCount   0;
console output:
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Constructing kinematicCloud kinematicCloud
Constructing particle forces
    none
Constructing cloud functions
    none
Constructing particle injection models
Creating injector: model1
Selecting injection model patchInjection
    Constructing 3-D injection
Selecting distribution model fixedValue
Selecting dispersion model none
Selecting patch interaction model none
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Reading non-inertial frame fields
Courant Number mean: 0.0317746 max: 0.213496
Starting time loop
Time = 0.5
Evolving kinematicCloud
ExecutionTime = 1.43 s  ClockTime = 2 s
Time = 1
ExecutionTime = 1.84 s  ClockTime = 2 s
Time = 1.5
ExecutionTime = 2.23 s  ClockTime = 2 s
Time = 2
ExecutionTime = 2.64 s  ClockTime = 3 s
Time = 2.5
ExecutionTime = 3.05 s  ClockTime = 3 s
Time = 3
ExecutionTime = 3.45 s  ClockTime = 4 s
Time = 3.5
ExecutionTime = 3.86 s  ClockTime = 4 s
Time = 4
ExecutionTime = 4.26 s  ClockTime = 4 s
Time = 4.5
ExecutionTime = 4.67 s  ClockTime = 5 s
Time = 5
Solving 3-D cloud kinematicCloud
Cloud: kinematicCloud injector: model1
    Added 10 new parcels
    Current number of parcels       = 10
    Current mass in system          = 0.008
    Linear momentum                 = (0 0 0)
   |Linear momentum|                = 0
    Linear kinetic energy           = 0
    model1:
        number of parcels added     = 10
        mass introduced             = 0.008
 ExecutionTime = 5.23 s  ClockTime = 5 s
kinematicCloudProperties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      kinematicCloudProperties;
solution
    active          true;
    coupled         false;
    transient       no;
    calcFrequency   10;   // calc pro cycle
    cellValueSourceCorrection off;
    maxCo           0.3;
    maxTrackTime 5;
    interpolationSchemes
        rho             cell;
        U               cellPoint;
        mu              cell;
    integrationSchemes
        U               Euler;
constantProperties
    rho0            1000;
    youngsModulus   1e8;
    poissonsRatio   0.35;
subModels
    particleForces
        //sphereDrag;
        //gravity;
    injectionModels
        /*model1
            type            manualInjection;
            massFlowRate        0.004583;
            massTotal       0;
            parcelBasisType fixed;
            nParticle       1;
            SOI             0;
            //positionsFile   "kinematicCloudPositions";
            U0              (0 0 0);
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   0.006;
        model1
        type patchInjection;
        parcelBasisType mass;
        patchName inlet;
        U0 (0 0 0);
        //nParticle 10;
        parcelsPerSecond 10;
        sizeDistribution
                    type        fixedValue;
                        value   0.000001;
                flowRateProfile constant 1;
                //massTotal 0.3;  //Choosing nParticle to be a fixed value, massTotal variable now             does not determine anything.
                SOI 0;
                duration 1;
                massFlowRate        0.8e-02;//0.0001;//0.004583;
    dispersionModel none;
    patchInteractionModel none;
    //patchInteractionModel standardWallInteraction;
    //standardWallInteractionCoeffs
      //      type        rebound; // stick, escape
     //       e           1;       // optional - elasticity coeff
    //        mu          0;       // optional - restitution coeff
    surfaceFilmModel none;
    stochasticCollisionModel none;
    collisionModel pairCollision;
controlDict:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     icoUncoupledKinematicParcelFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         10;
deltaT          0.5;
writeControl    timeStep;
writeInterval   1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
//functions
//    #includeFunc streamlines
I would be very grateful if someone could point me in the right direction!
particlecount_0 is offline   Reply With Quote
Old   March 6, 2021, 14:09
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
"console output" shows that 10 parcels were injected into the domain. therefore, there are definitely parcels in your domain unless they convected out of the domain. "particleCount" quantity seems to be taken from a processor file - maybe in the first processor data group, there is no parcel. maybe parcels reside in other processors. if the case is small, I would run it in serial with interim time-steps- just to observe it.
HPE is offline   Reply With Quote
lagrangian particles, no particles injected, particle count zerom
how to determine the number of particles injected. welch FLUENT 2 January 18, 2024 04:08
Distinguish particles injected from Injection Achini Fluent UDF and Scheme Programming 0 October 23, 2020 12:17
No particles injected in DPMFoam when nonSphereDrag particle force selected decah OpenFOAM Running, Solving & CFD 0 April 7, 2017 12:14
Nitrogen injected into a column filled with sand particles AndoniBM OpenFOAM 1 April 10, 2015 05:57
Defining New Material for Injected Particles Lior FLUENT 5 June 4, 2004 11:12
