Compressible flow solving - issues with "Floating point exception"
Old   August 7, 2021, 18:02
Unhappy Compressible flow solving - issues with "Floating point exception"
Ben
Ben786 is on a distinguished road
Hello everyone! I'm having trouble with solving this compressible flows problem and it seems like I can't get the solver to get going no matter what I do. The most common error I'm seeing is "Floating point exception" - perhaps my Google-fu isn't strong enough, but I can't seem to find a straight answer for what this actually means.
A little background on the problem:
I'm trying to simulate a CD nozzle that takes air (1500 K, 500 m/s, 10MPa) at its inlet. I've designed the nozzle such that the flow will be fully expanded and supersonic at the exit (100 kPa). Eventually, I want to be able to simulate the addition of solid nanoparticles in the flow, but that may be way above my current understanding...
The characteristic length is the nozzle inlet diameter (0.02 m) and calculated exit speed is 1610 m/s, giving deltaT an order of magnitude of around 1e-7.
I've attached my .geo(.txt) use for my mesh and a recent error output to this post, and also relayed my settings below.
Thank you in advance to anyone willing to take the time to help me!
# 0 #
p
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    inlet
//        type            totalPressure;
//        p0              uniform 1.29036e+07;
//        gamma		1.3;
//        value           uniform 1.29036e+07;
        type            fixedValue;
        value           uniform 1e7;
    exit
//        type            zeroGradient;
        type            fixedValue;
        value           uniform 1e5;
    top
        type            zeroGradient;
    bottom
        type            zeroGradient;
    front
        type            empty;
    back
        type            empty;
T
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    inlet
//        type            totalTemperature;
//        gamma           1.3;
//        T0              uniform 1725;
        type            fixedValue;
        value           uniform 1500;
    exit
        type            zeroGradient;
    top
//        type slip;
        type            zeroGradient;
    bottom
//        type slip;
        type            zeroGradient;
    front
        type            empty;
    back
        type            empty;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            zeroGradient;
        type            fixedValue;
        value           uniform (500 0 0);
//        type            pressureInletVelocity;
//        value           uniform (0 0 0);
    exit
        type            zeroGradient;
//        type            inletOutlet;
//        inletValue      uniform (0 0 0);
    top
        type            slip;
    bottom
        type            slip;
    front
        type            empty;
    back
        type            empty;
# System #
controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     rhoSimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.5;
deltaT          1.7391e-07; //1.7391e-07
writeControl    adjustableRunTime;
//writeControl    adjustable;
//writeControl    timeStep;
//writeInterval   575000;
writeInterval   0.01;
purgeWrite      0;
writeFormat     ascii;
writePrecision  7;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  true;
maxCo           0.5;
maxDeltaT       1;
fvSchemes
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss vanLeerV 1;
    div(phi,nuTilda) bounded Gauss vanLeer 1;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
    // Sxx - Szz are variables for Spalart-Shur correction
    div(phi,Sxx)    bounded Gauss linear;
    div(phi,Sxy)    bounded Gauss linear;
    div(phi,Sxz)    bounded Gauss linear;
    div(phi,Syx)    bounded Gauss linear;
    div(phi,Syy)    bounded Gauss linear;
    div(phi,Syz)    bounded Gauss linear;
    div(phi,Szx)    bounded Gauss linear;
    div(phi,Szy)    bounded Gauss linear;
    div(phi,Szz)    bounded Gauss linear;
    div(phid,p)     bounded Gauss linear;
    div(phiv,p)     bounded Gauss linear;
    div(phi,K)      bounded Gauss linear;
    div(phi,h)      bounded Gauss vanLeer 1;
    div(phi,Ekp)    bounded Gauss linear;
    div(phi,e)    bounded Gauss linear;
    div(((rho*nuEff)*dev2(T(grad(U)))))        Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    e
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-8;
        relTol           0;
    "rho.*"
        solver          diagonal;
    "p.*"
        tolerance        1e-8;
        relTol           0;
        solver           PBiCG;
        preconditioner
        preconditioner   GAMG;
        smoother         DIC;
        nPreSweeps       1;
        nPostSweeps      2;
        nFinestSweeps    2;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
*/         minIter         3;
        maxIter         1000;
    "U.*"
        type             coupled;
        solver           PBiCICG;
        tolerance        (1e-8 1e-8 1e-8);
        relTol           (0 0 0);
    "h.*"
        solver           PBiCG;
        tolerance        1e-8;
        relTol           0;
    "nuTilda.*"
        $h;
        tolerance        1e-8;
SIMPLE
    nNonOrthogonalCorrectors 3; // 0
    pRefCell 0;
    pRefValue 0;
    rhoMin          rhoMin [1 -3 0 0 0] 0.1; // 0.5
    rhoMax          rhoMax [1 -3 0 0 0] 30; // 2.0
    transonic       yes;
relaxationFactors
    fields
        p                 0.2;
        rho               1.0;
    equations
        U                 0.8;
        "(e|h)"           0.8;
        nuTilda           0.8;
# Constant #
thermophysicalProperties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
// We refer to absolute energy where heat of formation is included, and sensible energy where it is not
mixture
    specie
        nMoles          1;
        molWeight       28.96;
    thermodynamics
        Cp              1243.7;
        Hf              0;
    transport
        As              1.458e-6;
        Ts              110.4;
turbulenceProperties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      turbulenceProperties;
simulationType  laminar;
boundary
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
6
    back
        type            empty;
        physicalType    empty;
        nFaces          2293;
        startFace       3376;
    top
        type            wall;
        physicalType    wall;
        nFaces          44;
        startFace       5669;
    exit
        type            patch;
        physicalType    patch;
        nFaces          28;
        startFace       5713;
    bottom
        type            wall;
        physicalType    wall;
        nFaces          44;
        startFace       5741;
    inlet
        type            patch;
        physicalType    patch;
        nFaces          11;
        startFace       5785;
    front
        type            empty;
        physicalType    empty;
        nFaces          2293;
        startFace       5796;
Ben786 is offline   Reply With Quote
Old   August 7, 2021, 22:59
Default Update
Ben
I think I may have narrowed the issues down to the mesh itself, but I have zero idea what could be wrong with it??
Old   August 8, 2021, 05:50
Fouch is on a distinguished road
You should pay attention to the warning ta the begining of the log :
 rhoMin' specified rather than 'pMin' or 'pMinFactor'
    This is supported for backward-compatibility but 'pMin' or 'pMinFactor' are more reliable.
You may try with pMinFactor and pMaxFactor instead of rhoMin rhoMax and see if it’s better.
Cheers.
Fouch is offline   Reply With Quote
Old   August 8, 2021, 10:31
Default Didn't work :(
Ben
Originally Posted by Fouch View Post
Cheers.
Unfortunately, that didn't seem to do anything other than remove the warning...
compressible, nozzle, rhosimplefoam, transonic
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 02:42
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
