request for uniformDimensionedVectorField g from objectRegistry region0 failed
Like Tree1Likes
  • 1 Post By clapointe
Old   April 4, 2021, 03:54
Default request for uniformDimensionedVectorField g from objectRegistry region0 failed
Dylan James
dylan_OF is on a distinguished road
hi guys:
I get the following error when I execute the postProcess command. Does anyone know how I can fix this?
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : v2012 OPENFOAM=2012
Arch   : "LSB;label=32;scalar=64"
Exec   : postProcess
Date   : Apr 04 2021
Time   : 15:23:59
Host   : dyfluid
PID    : 3421
I/O    : uncollated
Case   : /home/dyfluid/OpenFOAM/OpenFOAM-v2012/run/waveExampleSolitary
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0
Reading fields:
Executing functionObjects
--> FOAM FATAL ERROR: (openfoam-2012)
    request for uniformDimensionedVectorField g from objectRegistry waveExampleSolitary failed
    available objects of type uniformDimensionedVectorField are
0()
    From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::UniformDimensionedField<Foam::Vector<double> >]
    in file /home/dyfluid/OpenFOAM/openfoam-master/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 463.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::exitOrAbort(int, bool) at ??:?
#2  Foam::UniformDimensionedField<Foam::Vector<double> > const& Foam::objectRegistry::lookupObject<Foam::UniformDimensionedField<Foam::Vector<double> > >(Foam::word const&, bool) const at ??:?
#3  Foam::functionObjects::interfaceHeight::writePositions() at ??:?
#4  Foam::functionObjects::interfaceHeight::write() at ??:?
#5  Foam::functionObjectList::execute() at ??:?
#6  ? in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/postProcess
#7  ? in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/postProcess
#8  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#9  ? in ~/OpenFOAM/OpenFOAM-v2012/platforms/linux64GccDPInt32Opt/bin/postProcess
Aborted (core dumped)
this is my controlDict file
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         50.0;
deltaT          0.1;
writeControl    adjustableRunTime;
writeInterval   1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.65;
maxAlphaCo      0.65;
maxDeltaT       0.05;
functions
    interfaceHeight
    	type		interfaceHeight;
    	libs		("libfieldFunctionObjects.so");
    	alpha		alpha.water;
    	locations	((39.85 1 1));
the version is v2012
the solver is interFoam
I will be appreciate for any advice.
dylan_OF is offline   Reply With Quote
Old   April 7, 2021, 19:38
clapointe is on a distinguished road
I would guess that the functionObject wants g loaded, but doesn't load it itself. Solvers now should have a postProcess flag, so that things are just loaded (like the gravity vector) but the solver doesn't progress and just post processes. This would be done with something like :
 <solver> -postProcess -func
So for your case, I'd guess something like :
 interFoam -postProcess -func interfaceHeight
Looks like something similar is done in this tutorial : https://develop.openfoam.com/Develop...otation/Allrun
Caelan
dylan_OF likes this.
Public git repository : https://github.com/clapointe2011/public
clapointe is offline   Reply With Quote
Old   April 7, 2021, 20:37
Dylan James
Thank you very much for your reply!So far, I've adopted paraview to implement my requirements.But your suggestion is great and comprehensive, I will try it and feedback the result.
Old   March 11, 2024, 02:44
Yupeng Duan
YupengDuan is on a distinguished road
Hi did you solve the problem? I use the interFoam -postProcess -func interfaceHeight but still failed
YupengDuan is offline   Reply With Quote
interfaceheight, interfoam, openfoam2012, postprocess
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
