Taylor Couette flow simulation with rotational cyclic B.C.
Old   April 14, 2021, 23:21
Default Taylor Couette flow simulation with rotational cyclic B.C.
engio is on a distinguished road
I was playing with Taylor-Couette flow (https://wiki.openfoam.com/index.php?...Andras_Horvath) to see whether axi-symmetric simulation is equivalent to the full domain simulation.
image link --- https://ibb.co/tHKJnXh
Editor's insert image icon doesn't work! How do I insert image?https://ibb.co/tHKJnXh
* The cases are... (top to bottom, left to right)
1. 5 degree cyclic wedge (structured hex mesh)
2. 30 degree cyclic wedge (structured hex mesh)
3. 60 degree cyclic wedge (structured hex mesh)
4. 180 degree cyclic wedge (structured hex mesh)
5. 360 degree full domain (structured hex mesh)
6. reference case(contributor Andras Horvath, snappyhexmesh?)
The 4th, 5th and 6th case show identical result. But for 1st, 2nd and 3rd case, the wavy pattern increased from 4 to 5 repetition.
My question is, is this behavior comes from cyclic B.C.?
Or, cyclic B.C.(axi-simmetry simulation) is not recommended for vortex flows like Taylor-Couette flow? (Or do I need some minimum azimuthal angle/distance for such flows?)
Any comment/advice is appreciated. Thanks.
engio is offline   Reply With Quote
wedge vs rotational cyclic boundary conditions? wildfire230 OpenFOAM Running, Solving & CFD 4 January 2, 2021 09:29
How to manage the pressure term in fixed mass flow rate based channel flow simulation sjwon1991 Main CFD Forum 5 July 10, 2017 07:21
Steady state free surface flow in rotational closed system hilde CFX 5 January 21, 2015 16:47
how to get a time-accurate solution in Flow Simulation drdet FloEFD, FloWorks & FloTHERM 4 January 20, 2015 07:11
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
