April 23, 2021, 16:22 |
OpenFoam 8 EHD wrong pressure
Aviator
Dear Sweet People,
I have developed a EHDsimpleFoam code fused from simpleFoam and electrostaticFoam. The development encompassed 4 things: 1) adding coulomb force to UEqn, as seen in attachments 2) writing EEqn based on electrostatic foam, as seen in attachments 3) adding #include EEqn in the main file, as seen in attachments 4) fused the CreateFields.C from both simpleFoam and electrostaticFoam. The Pressure equations I left unchanged. I am running the sim with RAS kepsilon, turbulence off (so laminar pretty much). The validation case that I am doing is at zero background velocity. All velocity is induced by ionic wind. The setup is half-domain, with symmetryPlane. It has emitter and collector, both being semi-circles (cause half-domain). THE PROBLEM: The velocity field seems nice, as attached. But the pressure field..... God Please.... what is this ??? Even the forceCoeffs outputs near 0 values for Cd at the big semi-circle.... I have been trying to figure it out why that happended but cant find a solution. If I run the same sim without charge, but set the inlet velocity to the value that was induced by ionic wind, then the pressure looks alright. QUESTION: How to fix the pressure ?? Last edited by aviatorr; April 23, 2021 at 16:26. Reason: new info |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
tank sloshing - getting wrong pressure | enghamed | CFX | 2 | April 26, 2011 22:09 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
