Chtmultiregionfoam + fvdom
Like Tree1Likes
  • 1 Post By lumpor
Old   June 22, 2021, 06:46
Default Chtmultiregionfoam + fvdom
Atieh.alizadeh is on a distinguished road
i want to model the greenhouse effect in a solarchimney, i have considered the ambient air and i want to study the effects of the solar chimney on the ambient air
so i need to model the solar radiation and use FVDOM (to model the transparent parts )
how can i consider solar radiation in my model?
Atieh.alizadeh is offline   Reply With Quote
Old   June 22, 2021, 07:38
Fabian Friberg
lumpor is on a distinguished road
Have you looked at the solarBeamWithTrees tutorial? It uses both solarLoad and FvDOM, so it could lend some inspiration.
I don't think OF support for semi-transparent boundaries is all there yet. I don't know exactly what your setup looks like, but I think most of the changes you want to do can be done in boundaryRadiationProperties. There you can set different absorptivities and emissitivities for different wavelengths of boundaries, you can make boundaries transparent or opaque, and you can set separate conditions for solid-to-air and air-to-solid.
Atieh.alizadeh likes this.
lumpor is offline   Reply With Quote
Old   June 22, 2021, 07:48
yes i have glass, concrete and earth
and the glass should have different absorption and transmission in different wavelenths
Old   June 22, 2021, 08:02
Fabian Friberg
Setting aborptivity for different wavelengths can be done in boundaryRadiationProperties but wavelength-dependent transmissivity is not implemented from what I know. All the if clauses in the solarLoad code only check for transmissivity == 0, not transmissivity < 1, and they only check a single value for each face, not multiple values, which probably means that they don't store multple transmissivities for each face. You're probably going to have to make modifications in the radiation library.
chtmultiregionfoam, fvdom, solar chimney, solar load
Error in thermophysical properties (chtMultiRegionFoam) mukut OpenFOAM Pre-Processing 28 November 23, 2021 06:34
Trying to validate fvDOM and view factors methods zfaraday OpenFOAM Running, Solving & CFD 33 August 25, 2021 07:58
FVDOM instability in wedge-type mesh Yuri Almeida OpenFOAM Running, Solving & CFD 4 November 9, 2017 22:41
chtMultiRegionFoam: crash with fvDOM and unstructured mesh Gidra OpenFOAM Bugs 3 May 6, 2017 09:15
Embed explicitSetValue in chtMultiRegionFoam samiam1000 OpenFOAM 2 April 18, 2012 05:14
