multiphaseEulerFoam with RAS only wroks with mixtureKEpsilon
Old   July 3, 2021, 17:32
Default multiphaseEulerFoam with RAS only wroks with mixtureKEpsilon
Gustavo
gustavoliveira is on a distinguished road
I am trying to run the damBreak case with two fases (air and water) with multiphaseEulerFoam. When I use the mixtureKEpsilon model works ok, but if I use the kEpsilon or kOmegaSST dont run, stops in the first cycle. Someone can help? The case is attached.
Other question is about diameter of the phases. The results seens very sensible to this parameters, the fluid with high values (1e-4) of diameter seens more viscous. Anyone has a good documentation about this? I cant found a good one.
Thanks.
gustavoliveira is offline   Reply With Quote
Error in LRR (RAS) model in OpenFOAM v4.1 Inquisitor101 OpenFOAM 4 November 29, 2023 15:11
DamBreak case multiphaseEulerFoam with RAS gustavoliveira OpenFOAM Running, Solving & CFD 2 December 3, 2021 20:14
Error running RAS kEpsilon quarkz OpenFOAM Running, Solving & CFD 1 December 31, 2018 04:10
Using RAS turbulence modelling in multiphaseEulerFoam (OF 2.1.1) anuragm OpenFOAM Running, Solving & CFD 0 November 26, 2014 10:45
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
