Diverging Solution when using turbulentMixingLengthDissipationRateInlet |
Marco
Rep Power: 4 ![]() |
Hi everyone!
I'm currently working on a case of an engine with the piston moving according to crank rod angle. The simulation works fine with rhoPimpleFoam and similar solvers, though I'm encountering this issue: when using both k-epsilon and k-omega, if I put a fixedValue at inlet, the simulations run nicely, while if I put the specification of turbulentMixingLengthDissipationRateInlet (or turbulentMixingLengthFrequencyInlet) , which is what I really want to use, the solvers crashes in few steps, generating the error of negative temperature. What do you think can be the main problem in setting this BC? Tell me if uploading the BC field or some dicts may help. Thank you very much! |
Uwe Pilz
Rep Power: 15 ![]() |
Such complicated b.c. are often developed and tested at a typical test case only. It may happen that they have not the stability which more general b.c. have.
Negative temeratures are the result of instable simulation. You should try two things: - Store the result frequently and look where the instability first occurs. Look at the mesh there. - Use more stable simulation conditions.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Marco
Thank you for your answer.
I don't think it is a mesh related issue, since I tried many different refinements but the outcome is always the same. Can i ask you to check is these numerics are stable enough? Do you think I should change something? Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default bounded Gauss upwind; div(phi,U) Gauss upwind; div(phi,e) Gauss upwind; div(phid,p) Gauss upwind; div(phi,K) Gauss upwind; div(phiv,p) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,burnt) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.5; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { p; } Code:
solvers { "(p|rho)" { solver GAMG; smoother DIC; tolerance 1e-8; relTol 0.01; } "(p|rho|pcorr)Final" { $p; //relTol 0; } "(U|k|epsilon|burnt|h)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.01; } "(U|k|epsilon|burnt|h)Final" { $U; relTol 0; } } PIMPLE { nOuterCorrectors 4; nCorrectors 3; nNonOrthogonalCorrectors 2; } relaxationFactors { equations { "(U|k|epsilon).*" 1; } } cache { grad(U); } |
Uwe Pilz
You may switch form upwind to linear upwind. It is more stable, but also more diffusive.
Do you have any relaxation? I recommend using it, at least at the beginning.
Marco
doesn't relaxation factors induce delay in unsteady simulations?
If not, how do you raccomand to impose them? |
Uwe Pilz
Yes, relaxation has an effect. But it is improtant that the simulation starts at all. You may stop it and reduce relaxation at later simulated time.
in fvSolution: Code:
relaxationFactors { "(U|T|k|epsilon|omega|R)" 0.7; "p" 0.3; }
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
Trimmer mesh problems - solution diverging | lightning0 | STAR-CCM+ | 9 | August 8, 2018 07:58 |
Diverging solution for hypersonic flow | lipiroy | SU2 | 1 | July 2, 2018 12:04 |
diverging solution in bubble rise | shash | FLUENT | 0 | August 11, 2012 16:39 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
