Diverging Solution when using turbulentMixingLengthDissipationRateInlet |
July 17, 2021, 09:21 |
Marco
Rep Power: 4 |
Hi everyone!
I'm currently working on a case of an engine with the piston moving according to crank rod angle. The simulation works fine with rhoPimpleFoam and similar solvers, though I'm encountering this issue: when using both k-epsilon and k-omega, if I put a fixedValue at inlet, the simulations run nicely, while if I put the specification of turbulentMixingLengthDissipationRateInlet (or turbulentMixingLengthFrequencyInlet) , which is what I really want to use, the solvers crashes in few steps, generating the error of negative temperature. What do you think can be the main problem in setting this BC? Tell me if uploading the BC field or some dicts may help. Thank you very much! |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
Trimmer mesh problems - solution diverging | lightning0 | STAR-CCM+ | 9 | August 8, 2018 07:58 |
Diverging solution for hypersonic flow | lipiroy | SU2 | 1 | July 2, 2018 12:04 |
diverging solution in bubble rise | shash | FLUENT | 0 | August 11, 2012 16:39 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
