August 9, 2021, 10:39 |
Checkerboarding problem_simpleFoam
Rep Power: 5 |
Hello Everyone,
I am working on very simple steady state solution (2D) of a channel flow using simpleFoam and having single cell along the flow direction (x). I have used periodic boundary condition for inlet and outlet, noSlip (for U) for the walls. I have tried different available fvSchemes. However, getting checkerboarding issue with p, Uy and Uz. Any suggestions to eliminate the issue will be highly appreciated. Thanks. Subho |
August 9, 2021, 11:18 |
Uwe Pilz
Rep Power: 15 |
First: Periodic b.c. often lead to problems. You are in 2D. It may be much better stacking some of the geometries and avoid periodicity in b.c.
Second: Checkerboarding is an issue of Mesh, may be combined with schemes. Try using a finer mesh.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
August 9, 2021, 12:18 |
Rep Power: 5 |
Many thanks for your reply Uwe. In my case, I have restrict to a 2D simulation. I have used fine mesh.
Subhojit |
August 9, 2021, 23:58 |
Uwe Pilz
Rep Power: 15 |
In most cases, the main question is not
How may I get my simulation running but How do I change my real world problem into a simulation. > I have restrict to a 2D simulation Normally, there are no such restrictions. We have to select the simulation which gives the most reliable results. Often, this is the simplest one. If you want to stay your simulation, I recommend using more stable schemes and relaxation.
August 13, 2021, 10:17 |
#5 | |
Rep Power: 5 |
Hello Uwe,
Thanks for your reply. I am using the following schemes Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; //cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) bounded Gauss limitedLinearV 1;//bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss limitedLinear 1; div(phi,epsilon) bounded Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; div((nu*dev2(T(grad(U))))) Gauss linear;//For LRR, SSG div(phi,R) bounded Gauss limitedLinear 1; //For LRR, SSG div(R) Gauss linear; //For LRR, SSG } laplacianSchemes { //default Gauss linear corrected; default Gauss linear orthogonal; } interpolationSchemes { default linear; //interpolate(U) linear; } snGradSchemes { //default corrected; default orthogonal; } fluxRequired { default no; p; } wallDist { method meshWave; } for p 0.3 and for rest 0.7. I have also tried with lower/higher relaxations. But no noticeable improvements. Subhojit Quote:
checkerboarding, simplefoam convergence, steady state |
Causes of checkerboarding | sturgeon | OpenFOAM Running, Solving & CFD | 15 | September 4, 2019 02:35 |
Checkerboarding > SimpleFoam | yambanshee | OpenFOAM | 2 | February 6, 2019 05:12 |
Checkerboarding | stuart23 | Main CFD Forum | 4 | October 16, 2012 09:36 |
Checkerboarding problem in LES | Matteo85 | OpenFOAM Running, Solving & CFD | 3 | September 15, 2012 22:15 |
Checkerboarding problem in LES | Matteo85 | OpenFOAM Running, Solving & CFD | 0 | June 9, 2009 09:47 |
