Aref for multi-element airfoil?
Like Tree1Likes
  • 1 Post By shereez234
Old   August 22, 2021, 17:01
Default Aref for multi-element airfoil?
GDS
GS
GDS is on a distinguished road
I am trying to run a "2D" case with a multi-element airfoil: a single element in the z-axis and the profile extruded to a depth of 1.0. I want to compare Cl and Cd with some published results, but I am not sure what to use for the reference area. The main airfoil and the flap overlap, and the flap is angled w.r.t. the main airfoil chord. The total chord of the two airfoils is greater than 1.0.
GDS is offline   Reply With Quote
Old   August 24, 2021, 04:52
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Usually for multi-element airfoils stowed chord is the right way to go.
Why don't you try to find the reference length from journal paper/s about this airfoil?
An alternative is to find the pressure coeff, Cp distribution graphs in the journal paper which will give you an idea of the reference lengths.
And the reference length for a simple airfoil is Cref_airfoil*depth (in 2d) for OpenFOAM.
mostafa kareem likes this.
shereez234 is offline   Reply With Quote
Old   August 24, 2021, 20:52
GDS
GS
Thanks for the reply, but I am a little confused when you say "reference length". I thought that was used for moment calculations. Did you mean "area"?
The only paper I have been able to access that has wind tunnel data has only Cp distributions and no force data, so there is no reference area/length given. The max x/c in the plots is about 1.2, which is about what the maximum x value is in the airfoil data file.
Old   August 25, 2021, 04:03
shereez234's Avatar
M Sereez
Correct me if I am wrong but in 2D, the reference length is the reference area for airfoil. ( In OpenFOAM this value gets multiplied by the extrusion depth i.e. how far your empty front and back planes are).
Have a look at how it was done for 30P30N multi-element airfoil in this paper, see Table 1.
https://research-information.bris.ac.../30P30N_LT.pdf
multi-element airfoil, reference area
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 13:46
Issues With Exporting From GMSH rberdon Mesh Generation & Pre-Processing 0 February 11, 2021 11:11
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 8, 2019 23:50
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
