Floating point exception k epsilon model
Old   August 20, 2021, 16:55
Default Floating point exception k epsilon model
Thibo
thibogoddef is on a distinguished road
Hello all,
Im running a flow simulation across an airfoil using the k epsilon model. With an inlet speed of 20m/s and I=0.05 I calculated k and epsilon. During the simulation I get an floating point error which i can not lose. The checkmesh function says the mesh is ok.
My k file:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1.5;
boundaryField
inlet
type fixedValue;
value uniform 1.5;
outlet
type zeroGradient;
airfoil
type kqRWallFunction;
value uniform 1.5;
frontAndBackPlanes
type empty;
my epsilon file:
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.30187;
boundaryField
inlet
type fixedValue;
value uniform 0.30187;
outlet
type zeroGradient;
airfoil
type epsilonWallFunction;
frontAndBackPlanes
type empty;
for p all the boundries are set to fixedValue =0.
How can I solve this floating point error?
Kind regards TG
thibogoddef is offline   Reply With Quote
Old   August 21, 2021, 01:40
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
This cannot be reached in finite areas.Set zero gradient at the inlet and at the airfoil.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 21, 2021, 09:41
Thibo
Hello Piu58
Thanks for the reply. After changing these setting the solution converges until it reaches 10 iterations after this there is a large jump and I get a new floating point error.
Do you have any idea how this could come?
Kind regads TG
Transonic Diffuser Case: Floating Point Exception Saleh Abuhanieh OpenFOAM Running, Solving & CFD 26 April 8, 2023 05:55
Floating Point exception (core dumped) chtMultiRegionFoam ayu12 OpenFOAM Running, Solving & CFD 1 October 12, 2021 11:31
Floating Point Exception - Mesh Related?? edomalley1 OpenFOAM Running, Solving & CFD 2 November 8, 2018 11:30
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 09:08
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
