dynamicMesh for several patches
Old   September 22, 2021, 06:30
Default dynamicMesh for several patches
Reptider is on a distinguished road
Hello!
There are used several patches constructed by createPatch from necessary faceSets. I use dynamicMeshDict for one certain patch (movingWall_POCO) that will be changed.
boundary file:
|  \\    /   O peration     | Version:  v1912                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
4
    movingWall_AETB
        type            wall;
        inGroups        1(wall);
        nFaces          129969;
        startFace       6430814;
    movingWall_TUFROC
        type            wall;
        inGroups        1(wall);
        nFaces          13899;
        startFace       6560783;
    movingWall_POCO
        type            wall;
        inGroups        1(wall);
        nFaces          12870;
        startFace       6574682;
    space_AETB
        type            wall;
        inGroups        1(wall);
        nFaces          36998;
        startFace       6587552;
dynamicMeshDict file:
|   \  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
	version	2.0;
	format		ascii;
	class		dictionary;
	location	"constant";
	object		dynamicMeshDict;
dynamicFvMesh		dynamicMotionSolverFvMesh;
motionSolverLibs	( "libfvMotionSolvers.so" );
solver			displacementLaplacian;
displacementLaplacianCoeffs
	diffusivity quadratic inversePointDistance (movingWall_POCO);
When I run my own solver I get next error:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
Applying solid body motion to entire mesh
Selecting motion diffusion: quadratic
Selecting motion diffusion: inversePointDistance
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib/x86_64-linux-gnu/libc.so.6
#3  Foam::inversePointDistanceDiffusivity::correct() at ??:?
#4  Foam::inversePointDistanceDiffusivity::inversePointDistanceDiffusivity(Foam::fvMesh const&, Foam::Istream&) at ??:?
#5  Foam::motionDiffusivity::addIstreamConstructorToTable<Foam::inversePointDistanceDiffusivity>::New(Foam::fvMesh const&, Foam::Istream&) at ??:?
#6  Foam::motionDiffusivity::New(Foam::fvMesh const&, Foam::Istream&) at ??:?
#7  Foam::quadraticDiffusivity::quadraticDiffusivity(Foam::fvMesh const&, Foam::Istream&) at ??:?
#8  Foam::motionDiffusivity::addIstreamConstructorToTable<Foam::quadraticDiffusivity>::New(Foam::fvMesh const&, Foam::Istream&) at ??:?
#9  Foam::motionDiffusivity::New(Foam::fvMesh const&, Foam::Istream&) at ??:?
#10  Foam::displacementLaplacianFvMotionSolver::displacementLaplacianFvMotionSolver(Foam::polyMesh const&, Foam::IOdictionary const&) at ??:?
#11  Foam::motionSolver::adddictionaryConstructorToTable<Foam::displacementLaplacianFvMotionSolver>::New(Foam::polyMesh const&, Foam::IOdictionary const&) at ??:?
#12  Foam::motionSolver::New(Foam::polyMesh const&, Foam::IOdictionary const&) at ??:?
#13  Foam::motionSolver::New(Foam::polyMesh const&) at ??:?
#14  Foam::dynamicMotionSolverFvMesh::dynamicMotionSolverFvMesh(Foam::IOobject const&) at ??:?
#15  Foam::dynamicFvMesh::addIOobjectConstructorToTable<Foam::dynamicMotionSolverFvMesh>::New(Foam::IOobject const&) at ??:?
#16  Foam::dynamicFvMesh::New(Foam::IOobject const&) at ??:?
Floating point exception (core dumped)
Where is the problem located?
Thanks by advance.
Reptider is offline   Reply With Quote
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 08:19
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 07:49
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 22:35
