put a probe on moving wall (overSetMesh) OFv2106.
Old   October 15, 2021, 08:22
Default put a probe on moving wall (overSetMesh) OFv2106.
H.Ham
kimou is on a distinguished road
Hi Foamers,
i work on solid plate impacting water (overCompressibleInterFlow).
I want to put a probe on plate wall and store pressure and alpha.water in time.
But my plate move, in this case i want that my probe also move with the same velocity.
how to do this dear Foamers ?
attached figure : alpha field (blue:water, red:air),the black frame within the domaine is the plate, and i want to put a probe in the bottom surface of the plate.
best regrets,
kimou is offline   Reply With Quote
Old   October 23, 2021, 13:11
s1291's Avatar
s1291 is on a distinguished road
You can use the probe function object with fixedLocations set to false.
You can find many tutorials using that. Here is a way to find about them:
grep -rn 'fixedLocations' $FOAM_TUTORIALS
s1291 is offline   Reply With Quote
Rotating Cylinder (Moving wall vs Moving reference frame vs Sliding mesh) hamed.majeed FLUENT 2 January 17, 2017 12:18
Moving Wall Condition on a Curved Wall qwe11rty22 FLUENT 3 August 25, 2016 01:45
problem about a periodic moving wall itsqi7 FLUENT 6 January 31, 2013 15:54
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
moving wall BC problem Sourabh Main CFD Forum 1 August 8, 2006 07:47
