How to calculate y-plus?
Like Tree68Likes
Old   April 17, 2013, 14:11
Default How to calculate y-plus?
Derek2580
rogerliu is on a distinguished road
My case is unsteady flow past a cylinder using LES. Re=3900
How can I calculate the y-plus?
does y-plus refer the distance from the first grid to the wall? Is it the smaller, the better?
Thanks!
rogerliu is offline   Reply With Quote
Old   April 17, 2013, 17:41
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
Type yPlusRAS or yPlusLES
If you have ras or les turbulency.
mj20 and EddySouth like this.
immortality is offline   Reply With Quote
Old   April 18, 2013, 04:21
HECKMANN Frédéric
fredo490 is on a distinguished road
Hello, y+ refers to the size of the mesh next to the wall compared to the fluid behavior. This number helps you to know where is your first cell center compared to the boundary layer thickness.
If you didn't study any boundary layer theory, you have to know that a boundary layer is composed of different parts. The one very close to the wall is dominated by viscous effects (= the viscous layer) and a bit outer you have the log layer.
To get an accurate simulation, your first cell center must be inside the viscous layer. We usually consider that a y+ smaller than 4 is required. Ideally, you should have a y+ smaller than 1 on all your surface. But there is no need to go to 1e-3 !
Be careful, the size of your first cell must correspond to your turbulence model. For example a RAS k-omega SST requires a y+ smaller than 1 but a k-epsilon standard requires a y+ between 30 and 60. I don't know about LES simulation but I guess it should be smaller than 1.
To get the yPlus, you can only do it as a post treatment (because you need to compute the velocity first). To get it, simply type "yPlusRas" or "yPlusLes" depending of your turbulence model. You can also write "yPlusLes -h" to get some help.
For example: yPlusRas -latestTime -compressible will only compute the yplus for your last export and it will apply a compressible correction (only use it with a compressible solver).
To get a rough estimation of the cell size you need next to the wall, you can use this tool:
http://www.cfd-online.com/Tools/yplus.php
fredo490 is offline   Reply With Quote
Old   April 18, 2013, 06:49
Ehsan
I wonder how we can calculate y+ at a laminar flow without any turbulent model? is it possible?
Hughtong likes this.
Old   April 18, 2013, 07:01
HECKMANN Frédéric
At first the y+ has nothing to do with CFD but it has to do with the boundary layer theory (this number was created in the 1930's). The definition is here : http://www.cfd-online.com/Wiki/Dimen...stance_(y_plus)
Yes this number has a meaning for a laminar flow but we don't really care for CFD cases. It is mainly used for turbulent flow because the models we use are based on some assumptions that need to be verified.
Old   July 1, 2013, 09:34
VS
VSass is on a distinguished road
I have some problems calculating y+ during a compressible flow. I use Spalart-Allmaras model and the output in the results files is mut, not nut, which is prerequisite for the calculation of y+. Any ideas?
VSass is offline   Reply With Quote
Old   July 1, 2013, 09:44
Ehsan
hi
search this site.there are some good threads with y+ for compressible flows.
do you use low-Re or high-Re?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
Old   July 1, 2013, 10:15
VS
I use high Re.
Old   July 1, 2013, 11:18
Ehsan
then use yPlusRAS -compressible its for high-Re models Vasilios.
Old   July 1, 2013, 12:10
VS
I use yPlusRAS but it needs the "nut" values for each time step. My solution outputs "mut" files. That's the problem.
Old   July 1, 2013, 12:21
Ehsan
type: "yPlusRAS -compressible" not only yPlusRAS
Old   July 1, 2013, 12:25
VS
Honestly,thanks!
Old   July 3, 2013, 05:27
VS
Well, using yPlusRAS -compressible works, but it plots a value of "0" in the field. Mut has an accepted distribution , but how come the distribution of yPlus is zero?
caoyinyue likes this.
Old   July 3, 2013, 08:23
Ehsan
where in the field? whats your case? if its something like shockTube maybe the flow has not reached there.
Old   February 26, 2014, 21:23
caoyong
caoyinyue is on a distinguished road
Hello, I used the yPlusLES for calculating the incompressible flow field. the distribution of yplus is alos zero. It is very strange. Have you found any solution? Could you give me some hint? Thanks very much
caoyinyue is offline   Reply With Quote
Old   January 8, 2015, 12:28
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hello FOAMers and Frédéric,
Edit: Continuation from http://www.cfd-online.com/Forums/ope...provement.html
Please correct me if I am wrong
From reading all the posts my understanding of y+ is that we have an approximate estimation using the online calculators and once the simulation is done using the estimated y for the required y+ we use the Existing OpenFOAM utilities to calculate the actual y+ values am I right ?
I have used the online tools to estimate my Y distance for a required y+ value of 30. Then after running my simulations the openFOAM utilities say that my y+ value is 12. so Now I believe to get much accurate flow behaviour close to the wall I have to change the size of the y again !!!.
I have completed my simulation and OpenFOAM says my y+ value is 12 and I want it to be 30. My question is how do i determine the size of my first cell that is my Y distance now !.
And also my Y distance should be varying around my geometry right ? since flow behaves differently and Y+ value after the simulation is different all around the airfoil how do I determine the Y distances for different regions.
Thanks a lot for your time and reply,
Regards,
Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius
Alhasan is offline   Reply With Quote
Old   January 8, 2015, 15:54
Petr Furmanek
petr.f. is on a distinguished road
- Yes, that's the usual way. At first you have to decide what level of precision in turbulence modelling in boundary layer do you need (nice overview: http://www.bakker.org/dartmouth06/engs150/11-bl.pdf).
- Not necessarily. It is true, that the simulation with y+ - 12 is more accurate than the one with y+ = 30, but in both cases you already don't capture behaviour in the viscous sublayer, you have to use the wall functions approach and hence model the buffer layer (at best). So the overall level of precision is the same. What differs is the refinement level of computational mesh (and the total number of cells). If you want shorter computational times then yes - re-mesh the case.
- what y+ is 12? The minimal or the average?
And also my y+ should be varying around my geometry right ? since flow behaves differently how do I determine the y distances for different regions.
- usually you set your minimal y+ to the desired value for the largest cells in your "critical" region (e.g. the one with separation or highest velocity...) so you are estimating y+ for the "worst" case.
P.
javierjap likes this.
petr.f. is offline   Reply With Quote
Old   January 8, 2015, 16:17
Alhasan's Avatar
Hasan K.J.
Hey Petr,
Thanks for your reply,
Let me explain what I am trying to do so you will get a better idea of what is happening I have described it in a different post here: http://www.cfd-online.com/Forums/ope...provement.html
on short note im just simulating a NACA 0012 airfoil
Patch 0 named CURV1 y+ : min: 0 max: 12.6672 average: 4.48469
I had calculated using the online Y+ estimator that for a Y+ of 30 the Y distance was 0.00033 meters for my case and I had meshed with 0.00033 as my first cell height around my airfoil using ICEM. I wanted Y+ as 30 since I wanted to use the wall functions and I have used wall functions for my simulation using KW-SST.
I have also attached an image of the Y+ and Y* distribution on the upper and lower surface of the Airfoil. I have used one of the altered yPlus utilities on the forums to find my y+ values as the existing yPlusRANS supposedly calculates y*.
I got into this Y+ checking because of the results I was getting was not great as shown in the other post I have provided link above.
- So my question is To be accurate should I have a Y+ of 30 (using WF) around the airfoil equally If yes, How will I calculate the Y distance needed for every region.
Thanks,
Hasan K.J
Old   January 8, 2015, 17:15
Petr Furmanek
Hi Hasan,
you don't have to generate the mesh so that your y+ is 30 all over the profile. Actually I don't think that's even possible. From your simulations you already know the maximal velocity on the profile. I would use it for new delta s estimate for desired y+ and generate the mesh with y+ = 30 in this region (so it will be smaller in other areas).
However, after reading your other post I have two questions:
- what are your boundary conditions for k and omega on the profile (slip wall) in the no-WF simulations?
- what is the topology of your mesh (H mesh, C mesh, O mesh) ? 200000 cells for 2D case is quite a lot. For your purpose I would go for a C-mesh with ~ 50000 cells (and that's with y+ = 1), like the one in the attached picture. Such a mesh you can get easily from Tecplot (if you have the license, not sure if they still offer time-limited demo) or Gridpro (the academic license used to be free) or with a little effort from cMesh or "simple simple airfoil mesher" - http://www.cfd-online.com/Forums/ope...-aerofoil.html
P.
Old   January 8, 2015, 17:35
Alhasan's Avatar
Hasan K.J.
Hi Petr,
Thanks for you reply,
- What do you mean by delta s estimate ? you mean to say I have to use the new velocity to get the y distance estimate using the online calculators
I have used fixed value on the airfoil surface wall with no slip
        type            fixedValue;
        value           uniform 1e-11;
what is the topology of your mesh ?
You are absolutely right 200,000 quite a lot but since I had good computation power just stuck to it how ever I had done a mesh dependency test with approximately 8 cases with no elements varying from 50,000 to 800,000.
Edit: I think my 200,000 is only as good as your 50,000 as my domain is big !!
I have used a C mesh and I have used ICEM and I have grown quite comfortable with that software as you can control the mesh very well with that software and I do have license for techplot360.
However I am interested in your meshing topology does it come under C-Mesh..? and isn't the outlet very close to the airfoil My domain is massive just to avoid any BC problems as suggested in the literature I have 10c above and 10 c below my geometry and 20c behind my airfoil as shown in the image, the mesh look ridiculously dense it is not its just paraFoam showing it like that.
I did go with the y+ of 1 for all my Mesh dependancy cases like u had suggested but the results were not promising but the result with WF looks some what reasonable and I am hoping for better results after the Y+ correction
Regards,
Hasan K.J
[swak4Foam] Problem to calculate grad(U) using swak4Foam Hugoles OpenFOAM Community Contributions 12 November 24, 2020 10:28
how to calculate flow properties along the first grid point near to the wall kiran OpenFOAM Post-Processing 2 September 12, 2010 12:59
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 04:10
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 02:57
How to calculate density of solid phase zhou Main CFD Forum 0 December 17, 1999 19:06
