Rep Power: 5 ![]() |
Dear All,
First of all, I'm sorry for the poor sentences because I don't speak English as my mother tongue. And my first post. I'd like to simulate the phenomenon that inject gas into supersonic flow as shown in attached image. This is a simulation injection at pressure ratios of 15 and 20 into M2.9 flow using sonicFoam. Flow field and injection gas are same ideal gases. However, I searched for a way to change the type of gas that erupted, but could not find it. ![]() I'm also thinking about using twoPhaseEulerFoam for this problem, and I'm working on it, but I get the following error and can't simulate. Code:
--> FOAM FATAL ERROR: (openfoam-2012) Requested dispersed phase from an unordered pair. From virtual const Foam::phaseModel& Foam::phasePair::dispersed() const in file phasePair/phasePair.C at line 87. FOAM exiting Is this impossible? Thank you. |
David GISEN
Rep Power: 17 ![]() |
I think that sonicFoam is not applicable for two phases.
Have a look here for suggestions of solvers, e.g. rhoReactingFoam? Gas injection in another gas |
Hi David,
Thank you for your reply. I overlooked rRF solver because there was no its tutorial in v2012. I'll give it a try. Thank you! Satium |
Display Modes | |
Having Problem solving 2D supersonic flow around a plug nozzle | chrislloyd | FLUENT | 7 | July 22, 2015 13:09 |
[How to obtain supersonic flow inside a supersonic wind tunnel ?] | yx213 | Siemens | 1 | September 17, 2014 13:52 |
Jet in Supersonic Crossflow, controlling mass flow rate | ChrisA | OpenFOAM Running, Solving & CFD | 3 | November 13, 2012 18:20 |
Supersonic flow | abishek | FLUENT | 3 | July 28, 2008 06:07 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
