November 2, 2021, 12:02 |
Open channel, roughness and y+
Miguel Hernandez
Rep Power: 5 |
I'm continuing my studies with interFoam (openFoam 2106) for open channel simulation.
I'm currently working on a simulation of a small river and a concrete bridge. I'm wondering how to consider the roughness of this two different surfaces. I was thinking to use the nutRoughWallFunction for both the bridge and the riverbed in the nut BC. Is this enough? And, what about the Ks values? For concrete I had supposed Ks = 0.002, but for the riverbed - using a formula I found on some past posts - Ks = 0.55 (Manning n = 0.035). And last but not least, what is the importance of y+ , and so the last wall cell dimension, in a simulation of this kind? Thanks in advance... |
November 4, 2021, 10:08 |
David GISEN
Rep Power: 16 |
Assuming you mean nutkRoughWallFunction and you want to use the kOmegaSST turbulence model, you'll have to put:
In the nut file, you'll want to define Cs = 0.5 (default value) and Ks in meters as the equivalent sand-grain roughness. 0.55 m definitely seems too large for a riverbed. If you really have rocks like this, you should represent them by their form, not by roughness. If not, try using your imagination/expertise instead of a formula Regarding y+: as long as you are using those wall functions (not low-Re turbulence modeling) and as long as you do not care about wall shear stress or exact velocity in the wall-adjacent cells, you can largely ignore it from my experience for water in open channels. Cheers, David |
Open channel flow over porous bed, interface roughness | narendrapatel111 | Fluent Multiphase | 0 | July 5, 2017 22:17 |
Wall function for concrete walls, open channel flow | tinu80 | OpenFOAM Running, Solving & CFD | 6 | November 9, 2016 11:16 |
Create simple open channel flow | hydr_eng1805 | FLOW-3D | 2 | October 24, 2014 07:35 |
Open Channel Flows in Star-CCM+ | aristoc | STAR-CCM+ | 4 | October 1, 2010 07:53 |
open channel problem (free surface) | Andy Chen | FLUENT | 4 | July 10, 2009 01:20 |
