Rotating porous region in pimplefoam
Old   February 5, 2022, 09:28
Default Rotating porous region in pimplefoam
Max Spencer
spenceme is on a distinguished road
I am trying to simulate a porous region that is rotating at the same omega as my rotating region using a rotating motion and AMI. The simulation runs fine, but does not give the behavior though the porous region as I would expect/like. I want the porous region to 'hold' the fluid it contains. I.e. with a very low porosity it would act like a pseudo wall and approach being non-existent with a very high porosity.
I have a similar steady state case running using MRF and the branch feature-porous-mrf. MRF model presents the anticipated velocities.
Two pictures attached: 1) the 'incorrect' behavior from pimplefoam currently, 2) a more correct expected velocity field coming from the 'feature-porous-mrf' branch running porousSimpleFoam.
This can be thought of as a simple annulus of a porous region that is rotated in a fluid. The porosity should pull the fluid along and eventually cause a flow similar to an impeller due to centrifugal forces.
I am currently using pimpleFoam with fvOptions to establish the porous region. Any suggestions if openfoam (v2112 currently) supports my needs, or how to change the setup/solver to reflect the porous region rotating?
|  \\    /   O peration     | Version:  v2112                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
porosity
	type            explicitPorositySource;
	explicitPorositySourceCoeffs
		selectionMode   cellZone;
		cellZone        porusBlockage;
		type            DarcyForchheimer;
	//	D	100;
	//	D	200;
		D	5e3;
	//	D	1000;
		d	($D $D $D);
//		f	(0 0 0);
		f	($D $D $D);
		coordinateSystem
			type	cartesian;
			origin  (0 0 0);
			coordinateRotation
				type axesRotation; //local cartesian coordinates
				e1      (1 0 0);
				e2      (0 1 0);
|  \\    /   O peration     | Version:  v2106                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs (fvMotionSolvers);
motionSolver    solidBody;
cellZone        innerCylinderSmall;
solidBodyMotionFunction  rotatingMotion;
origin      (0 0 0);
axis        (0 1 0);
omega       52; // rad/s (496.56 rpm)
spenceme is offline   Reply With Quote
Old   March 23, 2022, 12:02
Anirudh Kulkarni
Tempest is on a distinguished road
Did you solve this issue?
Tempest is offline   Reply With Quote
Old   March 24, 2022, 10:06
Max Spencer
No, i have not. It appears the porous region is assumed static in position. i.e. as if the 'brush' was stationary in my pictures.
Porous Region vs Porous Media Model fluid23 STAR-CCM+ 3 August 3, 2021 11:06
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
Rotating Region and mesh size QuentinMercier Autodesk Simulation CFD 1 May 29, 2013 14:12
How to separate the porous region? hesamgh OpenFOAM 1 March 4, 2013 17:58
velocity at porous region CHUBBY FLUENT 3 May 15, 2001 23:37
