February 25, 2022, 08:10 |
changeDictionary or foamDictionary
UOCFD
Rep Power: 5 |
I want to perform this change in file constant/cloudProperties
submodels { localInteractionCoeffs { patches ( "(WALL_.*|INLET)" { type rebound; e 1; mu 1; } bottom { type rebound; e 1; mu 1; } ); } } Code:
submodels { localInteractionCoeffs { patches ( "(WALL_.*|INLET)" { type rebound; e 1; mu 1; } bottom { type escape; } ); } } |
February 27, 2022, 13:09 |
Rep Power: 14 |
Yes, this is a little tricky isn't it, since the entry you want to change is buried inside the patches() list and foamDictionary will only go down as far as the list name, patches. It won't (as far as I am aware) allow you to edit a specific entry in the list.
I think that what you will need to do is to specify the full (updated) patches list (i.e. incl. the ones that are not changing), eg something like: Code:
foamDictionary -entry submodels.localInteractionCoeffs.patches -set "WALL_.* {type rebound; e 1; mu 1;} INLET {type rebound; e 1; mu 1;} bottom {type escape; }" constant/cloudProperties |
March 2, 2022, 03:30 |
UOCFD
Rep Power: 5 |
Thanks a lot!!!
With a little change but it works fine |
Accessing foamDictionary keyword ".*" | Tobermory | OpenFOAM Running, Solving & CFD | 3 | March 5, 2021 16:46 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
[OpenFOAM.com] OpenFOAMv1806 with amd aocc 1.2 / 1.3 compiler | cfdx | OpenFOAM Installation | 10 | February 27, 2019 04:59 |
Fatal error: invalid wall function specification | kcc49 | OpenFOAM Running, Solving & CFD | 13 | September 26, 2018 04:07 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 11:05 |
