February 28, 2022, 02:37 |
Allow change of inlet velocity due to 6dof
TWB
Rep Power: 19 |
I'm trying to simulate a plane with an initial incoming velocity. Due to drag, it's supposed to slow down over time. Can we simulate this problem with OF and 6dof? So assuming that the plane body is fixed wrt to the domain with an initial incoming speed. At each timestep, the drag force is calculate from OF and with the wt of the plane know, we can calculate its deceleration and hence reduction in speed. Then we can update its incoming BC to the new lower speed. Is this feasible or has someone done it before? Thanks! |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
using outlet velocity profile as inlet for next set of iterations | tricha122 | FLUENT | 0 | November 22, 2020 09:40 |
How can it possible to change by itself in volumetric flow rate of velocity inlet BC | oozcan | FLUENT | 10 | November 25, 2016 04:54 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 09:44 |
