How to set empty field in multiphaseEulerFoam
Old   April 25, 2022, 22:00
Default How to set empty field in multiphaseEulerFoam
Akshay
enthusiast is on a distinguished road
Dear foamers,
I have a geometry with one inlet where the two-phase (water-oxygen) enters the square container which is half-filled with water.
I need to keep the other half empty so that I can collect the data of oxygen separation from water, but I am not able to not set the other half, as the solver don't run without setting it.
defaultFieldValues
    volScalarFieldValue alpha.oxygen 0
    volScalarFieldValue alpha.water 0
regions
	boxToCell
		box (0 0 0) (1.2 0.4 1);
        fieldValues
			volScalarFieldValue alpha.water 1
I tried it but no use, can someone please suggest how I can to initialize cells without alpha of any phase.
I am using openfoam version 8.
I have attached the fields set with alpha.oxygen as 1 and alpha.water as 0, this was the only way for me to run the simulation.
Can someone please suggest how I can set an empty intial phase property for the space above water in the container?
Thank you
Akshay
enthusiast is offline   Reply With Quote
two phase euler foam
Using gnuplot to plot probe data Rotidpor OpenFOAM 3 March 9, 2022 05:44
Set boundary value of 1 field equal to another field Saideep OpenFOAM 3 October 31, 2016 09:58
[snappyHexMesh] sHM quality of multi-region aminem OpenFOAM Meshing & Mesh Conversion 0 April 16, 2015 11:38
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 10:15
