[Sponsors] | |||||
Problems with adding gravity field in icoFoam |
ZY GONG
Rep Power: 5 ![]() |
Hi Foamers,
I try to add gravity field in icoFoam to simulate natural cycle. I added gravity term in UEqn and external heat source in TEqn.Then and run my code in the Square Cavity Flow.When I got the result,I found the mesh velocity for the upper and lower boundary regions is very large,but the mesh velocity of the inner area looks normal. The same is true for calculating only one step.I can't understand where my problem is and how should I fix it. I'm guessing there might be a problem with the pressure correction.I will put my code and data at the end.For the convenience of calculation, I changed the unit of g Q rho.And The version I am using is OF9. Thanks very much. GZY Code:
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
#include "setRootCaseLists.H"
#include "createTime.H"
#include "createMesh.H"
pisoControl piso(mesh);
#include "createFields.H"
#include "initContinuityErrs.H"
int ixx;
double ttt[50000];
double r[50000];
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
ixx=0;
forAll(T, cellI)
ttt[ixx]=T[cellI];
r[ixx]=11112.0-1.375*ttt[ixx];
rho[cellI]=r[ixx];
ixx++;
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "CourantNo.H"
// Momentum predictor
fvVectorMatrix UEqn
fvm::ddt(rho,U)
+rho*fvm::div(phi, U)
-rho*fvm::laplacian(nu, U)
-rho*g
if (piso.momentumPredictor())
solve(UEqn == -fvc::grad(p));
// --- PISO loop
while (piso.correct())
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
surfaceScalarField phiHbyA
"phiHbyA",
fvc::flux(HbyA)
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
adjustPhi(phiHbyA, U, p);
// Update the pressure BCs to ensure flux consistency
constrainPressure(p, U, phiHbyA, rAU);
// Non-orthogonal pressure corrector loop
while (piso.correctNonOrthogonal())
// Pressure corrector
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (piso.finalNonOrthogonalIter())
phi = phiHbyA - pEqn.flux();
#include "continuityErrs.H"
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
- Q
TEqn.solve();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
FoamFile
format ascii;
class volVectorField;
location "0.005";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField nonuniform List<vector>
400
(-0.000476508 -0.0115647 0)
(-0.000784292 -0.0141864 0)
(-0.000701793 -0.0145204 0)
(-0.000441974 -0.0144738 0)
(-0.000303848 -0.01444 0)
(-0.000210945 -0.014424 0)
(-0.000155563 -0.0144202 0)
(-0.000103963 -0.0144227 0)
(-6.11593e-05 -0.0144235 0)
(-2.02327e-05 -0.0144246 0)
(1.83156e-05 -0.0144272 0)
(5.45208e-05 -0.0144308 0)
(9.28129e-05 -0.0144343 0)
(0.000138576 -0.0144355 0)
(0.000195968 -0.0144346 0)
(0.000279105 -0.0144434 0)
(0.000425148 -0.0144788 0)
(0.000690445 -0.0145067 0)
(0.000775659 -0.0141518 0)
(0.000464067 -0.0115457 0)
(-0.000279845 0.00058314 0)
(-0.000574868 6.00372e-05 0)
(-0.000647177 -0.000375036 0)
(-0.000525152 -0.000333578 0)
(-0.000396586 -0.000237777 0)
(-0.000283292 -0.000197922 0)
(-0.000200873 -0.000172021 0)
(-0.000135336 -0.000162975 0)
(-8.11926e-05 -0.000157578 0)
(-2.98633e-05 -0.000155306 0)
(2.02394e-05 -0.000156322 0)
(7.29662e-05 -0.000160124 0)
(0.000136072 -0.000168787 0)
(0.000212373 -0.000185309 0)
(0.000300992 -0.000211916 0)
(0.000407737 -0.000257972 0)
(0.000539512 -0.000338687 0)
(0.000669973 -0.000374779 0)
(0.000571927 7.23082e-05 0)
(0.000267958 0.000585769 0)
(-0.000146075 0.00146615 0)
(-0.000302954 0.00091659 0)
(-0.000400162 0.000154317 0)
(-0.000367859 0.000105362 0)
(-0.000309357 0.000191787 0)
(-0.000246301 0.000248938 0)
(-0.000177506 0.000285114 0)
(-0.0001239 0.000304454 0)
(-7.58013e-05 0.000316463 0)
(-2.88559e-05 0.000322221 0)
(1.74775e-05 0.000323569 0)
(6.47452e-05 0.000321497 0)
(0.000120121 0.000311088 0)
(0.0001874 0.000286184 0)
(0.000259934 0.00024447 0)
(0.000329647 0.000181473 0)
(0.000392799 0.000100537 0)
(0.000416622 0.000136878 0)
(0.000306533 0.000893589 0)
(0.000123069 0.00148334 0)
(-0.000103847 0.00129893 0)
(-0.00018492 0.000686034 0)
(-0.000256443 -0.000221688 0)
(-0.000256455 -0.000325991 0)
(-0.000228186 -0.000287855 0)
(-0.000191544 -0.000227248 0)
(-0.000147711 -0.00019162 0)
(-0.000105681 -0.00016832 0)
(-6.46852e-05 -0.000152233 0)
(-2.33659e-05 -0.000143875 0)
(1.96885e-05 -0.000140995 0)
(6.18209e-05 -0.000140798 0)
(0.000104104 -0.000146745 0)
(0.000151296 -0.000167606 0)
(0.000200794 -0.000209243 0)
(0.000242342 -0.000271219 0)
(0.000265512 -0.000329492 0)
(0.000257181 -0.000226404 0)
(0.000174954 0.000673636 0)
(6.56123e-05 0.00130062 0)
(-6.06883e-05 0.00135316 0)
(-0.000125181 0.000754353 0)
(-0.000161296 -0.000204864 0)
(-0.000175726 -0.000350977 0)
(-0.000173099 -0.000326226 0)
(-0.000144624 -0.00028089 0)
(-0.00011779 -0.000247851 0)
(-8.43999e-05 -0.000222369 0)
(-5.13396e-05 -0.000203586 0)
(-1.76159e-05 -0.000192964 0)
(2.05519e-05 -0.000190593 0)
(5.89788e-05 -0.000194886 0)
(9.31998e-05 -0.000205482 0)
(0.000124114 -0.00022569 0)
(0.000150879 -0.000261492 0)
(0.000171882 -0.000310083 0)
(0.000179313 -0.000346719 0)
(0.000167005 -0.000194923 0)
(0.000112448 0.000763859 0)
(4.92095e-05 0.00136683 0)
(-2.70273e-05 0.00138085 0)
(-7.09724e-05 0.000796374 0)
(-0.000107227 -0.000168792 0)
(-0.000117999 -0.000360173 0)
(-0.000120237 -0.000335366 0)
(-0.000107655 -0.0003045 0)
(-8.83872e-05 -0.000274656 0)
(-6.12995e-05 -0.000251233 0)
(-3.52628e-05 -0.000234299 0)
(-1.03709e-05 -0.000223323 0)
(1.77641e-05 -0.000220531 0)
(4.69153e-05 -0.000228229 0)
(7.31836e-05 -0.000245872 0)
(9.44838e-05 -0.000271115 0)
(0.000110886 -0.000306219 0)
(0.000119251 -0.000344077 0)
(0.000120852 -0.000359249 0)
(0.000115228 -0.000177217 0)
(7.97267e-05 0.000803964 0)
(3.83064e-05 0.0014104 0)
(-1.6703e-05 0.00141444 0)
(-3.61677e-05 0.00083495 0)
(-6.53342e-05 -0.000147352 0)
(-8.21881e-05 -0.000344961 0)
(-7.94882e-05 -0.000341308 0)
(-7.83826e-05 -0.00031741 0)
(-6.37168e-05 -0.00029073 0)
(-4.39258e-05 -0.000271722 0)
(-2.34131e-05 -0.0002606 0)
(-3.845e-06 -0.000253703 0)
(1.56437e-05 -0.000251971 0)
(3.36205e-05 -0.000258951 0)
(5.01968e-05 -0.000276594 0)
(6.296e-05 -0.000302396 0)
(7.23847e-05 -0.00033215 0)
(8.09131e-05 -0.000361436 0)
(8.60585e-05 -0.000358308 0)
(7.65403e-05 -0.000161845 0)
(4.99976e-05 0.000828385 0)
(1.86187e-05 0.00144306 0)
(-5.37094e-06 0.00143108 0)
(-2.21076e-05 0.000880941 0)
(-3.65244e-05 -0.0001379 0)
(-5.17891e-05 -0.000329686 0)
(-5.47333e-05 -0.00034505 0)
(-5.15419e-05 -0.000323492 0)
(-4.18926e-05 -0.00029992 0)
(-3.10514e-05 -0.000282762 0)
(-1.72268e-05 -0.00027413 0)
(-1.73994e-06 -0.000271222 0)
(1.2514e-05 -0.000273632 0)
(2.22753e-05 -0.000281577 0)
(2.96213e-05 -0.000295393 0)
(3.8121e-05 -0.000315964 0)
(4.63096e-05 -0.000336938 0)
(5.51392e-05 -0.00035452 0)
(6.02754e-05 -0.000342835 0)
(4.68219e-05 -0.000143088 0)
(2.73084e-05 0.000863295 0)
(3.03072e-06 0.00146559 0)
(1.12998e-06 0.00144226 0)
(-1.49048e-05 0.000897853 0)
(-2.69431e-05 -0.000119724 0)
(-2.91617e-05 -0.000327525 0)
(-3.53389e-05 -0.000342124 0)
(-2.77164e-05 -0.00032369 0)
(-2.21796e-05 -0.000305454 0)
(-1.80188e-05 -0.00028991 0)
(-1.18553e-05 -0.000280293 0)
(-3.34473e-06 -0.000277348 0)
(5.28575e-06 -0.000281954 0)
(1.18427e-05 -0.000292742 0)
(1.56928e-05 -0.000305616 0)
(2.06077e-05 -0.000320302 0)
(2.82915e-05 -0.000336329 0)
(3.70589e-05 -0.000348993 0)
(3.73128e-05 -0.000337925 0)
(2.91021e-05 -0.000137081 0)
(1.7157e-05 0.000880993 0)
(3.30246e-06 0.00147645 0)
(-1.56015e-06 0.00146079 0)
(-1.21387e-05 0.000882067 0)
(-1.46624e-05 -0.000117336 0)
(-1.40117e-05 -0.000335749 0)
(-1.29428e-05 -0.000342116 0)
(-9.33577e-06 -0.000326634 0)
(-7.30431e-06 -0.000312759 0)
(-5.77275e-06 -0.000300222 0)
(-4.64805e-06 -0.000290631 0)
(-3.39861e-06 -0.000286618 0)
(-2.88267e-06 -0.000289264 0)
(-1.40338e-06 -0.000298825 0)
(1.94434e-06 -0.000311816 0)
(6.60057e-06 -0.000324948 0)
(1.20809e-05 -0.000340242 0)
(1.55854e-05 -0.000356148 0)
(1.20084e-05 -0.000351515 0)
(1.31528e-05 -0.000145057 0)
(7.55417e-06 0.000864676 0)
(4.69622e-06 0.00148753 0)
(4.65326e-07 0.00146405 0)
(-4.86963e-06 0.000879666 0)
(4.4215e-06 -0.000127734 0)
(6.2362e-06 -0.000337023 0)
(1.17325e-05 -0.000344929 0)
(7.17696e-06 -0.000331373 0)
(5.04003e-06 -0.000316971 0)
(4.22683e-06 -0.000305334 0)
(1.76543e-06 -0.000295904 0)
(-1.97513e-06 -0.000291222 0)
(-6.92348e-06 -0.000291289 0)
(-1.07265e-05 -0.000296302 0)
(-1.05476e-05 -0.00030599 0)
(-8.62608e-06 -0.00031926 0)
(-8.44592e-06 -0.00033682 0)
(-1.21709e-05 -0.00035665 0)
(-1.17752e-05 -0.000351366 0)
(-9.95408e-06 -0.000139387 0)
(-6.91761e-06 0.00086166 0)
(-4.45231e-06 0.0014964 0)
(3.00096e-06 0.00146342 0)
(5.83287e-06 0.000886522 0)
(1.97425e-05 -0.0001312 0)
(2.89706e-05 -0.000333301 0)
(3.06631e-05 -0.000349255 0)
(2.41587e-05 -0.000335492 0)
(1.95427e-05 -0.000316445 0)
(1.54124e-05 -0.000301385 0)
(9.48059e-06 -0.000291166 0)
(1.21881e-06 -0.000285598 0)
(-7.96511e-06 -0.00028456 0)
(-1.6122e-05 -0.000287413 0)
(-2.11313e-05 -0.000295223 0)
(-2.50372e-05 -0.000310045 0)
(-3.0846e-05 -0.000330894 0)
(-3.69171e-05 -0.000351411 0)
(-3.09075e-05 -0.000338626 0)
(-2.96076e-05 -0.000134597 0)
(-1.58574e-05 0.000882293 0)
(-8.68051e-06 0.00148029 0)
(6.11444e-06 0.00146733 0)
(1.74452e-05 0.000861518 0)
(3.58317e-05 -0.000145923 0)
(4.83584e-05 -0.00034781 0)
(4.74971e-05 -0.00036128 0)
(4.55242e-05 -0.000341454 0)
(3.99551e-05 -0.000318099 0)
(2.96226e-05 -0.000297494 0)
(1.75686e-05 -0.000284228 0)
(4.63374e-06 -0.000276861 0)
(-8.74037e-06 -0.000275175 0)
(-2.14071e-05 -0.000278382 0)
(-3.32968e-05 -0.000287723 0)
(-4.51039e-05 -0.00030618 0)
(-5.53495e-05 -0.00033121 0)
(-5.78604e-05 -0.00035268 0)
(-5.51394e-05 -0.000341056 0)
(-4.17093e-05 -0.000149888 0)
(-2.50979e-05 0.000873629 0)
(-8.17557e-06 0.00146295 0)
(1.63191e-05 0.00145682 0)
(3.76641e-05 0.000816578 0)
(6.42587e-05 -0.000175604 0)
(7.37901e-05 -0.000370354 0)
(7.49747e-05 -0.000368946 0)
(7.28761e-05 -0.000337561 0)
(6.43102e-05 -0.000308994 0)
(4.94009e-05 -0.000286287 0)
(3.01309e-05 -0.000270199 0)
(1.02742e-05 -0.000260533 0)
(-9.48786e-06 -0.00025776 0)
(-2.86872e-05 -0.00026188 0)
(-4.90471e-05 -0.000273767 0)
(-6.93317e-05 -0.000294926 0)
(-8.28835e-05 -0.000322104 0)
(-8.47195e-05 -0.000346659 0)
(-8.82926e-05 -0.000350875 0)
(-6.80694e-05 -0.000156493 0)
(-4.18766e-05 0.000830494 0)
(-1.67365e-05 0.00145478 0)
(2.74598e-05 0.00143012 0)
(6.74051e-05 0.00078216 0)
(0.000106065 -0.000201189 0)
(0.000115184 -0.000375339 0)
(0.000118243 -0.000353124 0)
(0.000111012 -0.00031365 0)
(9.20368e-05 -0.000280461 0)
(6.85353e-05 -0.000258283 0)
(4.33395e-05 -0.000242893 0)
(1.70742e-05 -0.000233873 0)
(-1.00894e-05 -0.000232419 0)
(-3.7431e-05 -0.000239524 0)
(-6.6461e-05 -0.000255126 0)
(-9.42483e-05 -0.000278235 0)
(-0.000112618 -0.000307016 0)
(-0.000124585 -0.000339418 0)
(-0.000125142 -0.000360898 0)
(-0.000114887 -0.000171221 0)
(-6.54621e-05 0.000792436 0)
(-2.17338e-05 0.00141799 0)
(3.6731e-05 0.00139133 0)
(0.000106338 0.000742242 0)
(0.000164733 -0.000216152 0)
(0.000181967 -0.000360473 0)
(0.000174601 -0.000323063 0)
(0.000151071 -0.000276932 0)
(0.000120484 -0.000242087 0)
(8.7086e-05 -0.000219654 0)
(5.45574e-05 -0.000205837 0)
(2.075e-05 -0.000199047 0)
(-1.5141e-05 -0.000200027 0)
(-5.14106e-05 -0.000210086 0)
(-8.78752e-05 -0.000228477 0)
(-0.000122028 -0.00025331 0)
(-0.000149598 -0.000286626 0)
(-0.00017654 -0.000332725 0)
(-0.000180209 -0.000360032 0)
(-0.000168915 -0.000217211 0)
(-0.000110239 0.000753172 0)
(-3.17183e-05 0.00136639 0)
(6.07837e-05 0.00132863 0)
(0.000178459 0.000666719 0)
(0.000261387 -0.000230396 0)
(0.00026809 -0.000333102 0)
(0.000239646 -0.000280786 0)
(0.000197503 -0.000227572 0)
(0.000150117 -0.000191273 0)
(0.000104903 -0.000168191 0)
(6.39635e-05 -0.000154842 0)
(2.2886e-05 -0.000148427 0)
(-2.11305e-05 -0.000148561 0)
(-6.58981e-05 -0.000156504 0)
(-0.000109801 -0.000172362 0)
(-0.0001532 -0.000196627 0)
(-0.000197548 -0.000235648 0)
(-0.000235855 -0.000294126 0)
(-0.000269448 -0.000332287 0)
(-0.000257508 -0.000239968 0)
(-0.000174341 0.000672084 0)
(-6.59362e-05 0.00130697 0)
(0.000129858 0.00151113 0)
(0.000317835 0.000901535 0)
(0.000422243 0.000145241 0)
(0.000389877 0.000102005 0)
(0.000317646 0.000176802 0)
(0.000246027 0.00023391 0)
(0.000180653 0.000270772 0)
(0.000123631 0.00029454 0)
(7.43384e-05 0.000308284 0)
(2.70326e-05 0.000314659 0)
(-2.32206e-05 0.000315856 0)
(-7.52278e-05 0.00031197 0)
(-0.000128112 0.000301163 0)
(-0.000186102 0.000278804 0)
(-0.000252539 0.000237348 0)
(-0.000310695 0.000178495 0)
(-0.000384351 0.000100987 0)
(-0.000419006 0.000156826 0)
(-0.000301551 0.000911537 0)
(-0.000119368 0.00148901 0)
(0.000276081 0.000602357 0)
(0.000580548 8.68364e-05 0)
(0.000673144 -0.000368828 0)
(0.000532516 -0.000341173 0)
(0.0003958 -0.000261237 0)
(0.000288954 -0.000211701 0)
(0.000206308 -0.000182384 0)
(0.000139103 -0.000164107 0)
(8.20563e-05 -0.00015369 0)
(2.95404e-05 -0.000148889 0)
(-2.36009e-05 -0.000147626 0)
(-7.90156e-05 -0.000149339 0)
(-0.00013961 -0.000155894 0)
(-0.00021159 -0.000172872 0)
(-0.000293944 -0.000207094 0)
(-0.000397102 -0.000251231 0)
(-0.000524323 -0.000339575 0)
(-0.000654217 -0.000357801 0)
(-0.000568395 8.83562e-05 0)
(-0.000257792 0.00059742 0)
(0.000468668 -0.0115389 0)
(0.000792462 -0.014146 0)
(0.000711709 -0.0145149 0)
(0.000449865 -0.014498 0)
(0.000301484 -0.0144619 0)
(0.000212398 -0.0144417 0)
(0.000149998 -0.0144296 0)
(0.000100535 -0.0144206 0)
(5.86655e-05 -0.0144149 0)
(1.99577e-05 -0.0144127 0)
(-1.85699e-05 -0.014412 0)
(-5.73086e-05 -0.0144113 0)
(-9.84487e-05 -0.0144123 0)
(-0.000147885 -0.0144192 0)
(-0.000205072 -0.0144354 0)
(-0.000302038 -0.0144533 0)
(-0.000447744 -0.0144797 0)
(-0.000711567 -0.014507 0)
(-0.000787918 -0.0141431 0)
(-0.000457033 -0.0115368 0)
boundaryField
Wall
type noSlip;
fixedWalls
type noSlip;
frontAndBack
type empty;
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problems with adding gravity field in icoFoam | Gzy52597 | OpenFOAM Running, Solving & CFD | 0 | May 3, 2022 03:10 |
| chtMultiRegion not solving for velocity field | obiscolly50 | OpenFOAM Running, Solving & CFD | 22 | November 9, 2018 14:40 |
| [swak4Foam] Need to use gravity field for defining the expression in swakFunction | Esmaeelef | OpenFOAM Community Contributions | 5 | May 1, 2017 18:01 |
| chtMultiRegionSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 39 | March 31, 2016 09:43 |
| Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
