questions on movingCylinderInChannellco in Foam-Extend 4.1 |
May 31, 2022, 09:35 |
cyh
hi everyone. I'm new to fe41 and currently studying ibm in it.I already read Hrvoje Jasak's ppt but still confused at the tutorial case of movingCylinderInChannellco.
1.Jasak's ppt said "copy immersed boundary mesh (ibCylinder,{ftr,stl}) into constant/triSurface folder". I am confused at the ibCylinder.ftr . It read as follows: 1 ( cylinder patch ) 96 ( (0.176776 -0.176776 -0.05) (0.176776 -0.176776 0.05) ... (-0.095671 -0.23097 -0.05) ) 96 ( ((0 64 65) 0) ((65 1 0) 0) ... ((7 6 79) 0) ) it seems that the first part is the list of coordinate of the vertex which is numbered from 0~95,the second part is a list of triangle faces defined by three vetexs, but what does the following 0 mean? for example, I know (0 64 65) is a triangle surface ,but what does the other 0 mean in((0 64 65) 0)? 2.If the lagrange vertexes are defined that way,how can I set up an ib structure that can defrom? For example,let half of the vertex of the cylinder move with prescribed velocity and let the other half move passively. Other ibm software like ibamr or ib2d gives structer like spring,beam...etc, how ib in fe41 work to deal with fsi ,or ib structers' passive deformation? |
foam-extend 4.1, immersed boundary method. |
[foam-extend.org] Installing Foam Extend 4.0 on Linux Mint | andysuth | OpenFOAM Installation | 1 | May 11, 2019 08:37 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
