Error in Parallel Running
Like Tree2Likes
  • 2 Post By ZeinabM
Old   June 28, 2022, 04:18
Default Error in Parallel Running
Zeinab Abosedaira
ZeinabM is on a distinguished road
Hello all,
I hope you're doing good. I was running a case in parallel, and I got the following error. It's not my first time running a case in parallel. I checked another case to make sure that the problem is not in the case directory, but I got the same error message. Thank you for your help.
Application : pimpSuzFoam (4 processes)
Output      : log
Executing   : /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64Gcc63/openmpi-4.0.3/bin/mpirun -n 4 /opt/OpenFOAM/OpenFOAM-v2012/bin/tools/foamExec pimpSuzFoam -parallel
[DESKTOP-T88LCC7:00925] opal_ifinit: unable to find network interfaces.
[DESKTOP-T88LCC7:00925] pmix_ifinit: unable to find network interfaces.
[DESKTOP-T88LCC7:00925] ptl_tcp: problems getting address for index 0 (kernel index -1)
[DESKTOP-T88LCC7:00925] oob_tcp: problems getting address for index 0 (kernel index -1)
No network interfaces were found for out-of-band communications. We require
at least one available network for out-of-band messaging.
ZeinabM is offline   Reply With Quote
Old   June 29, 2022, 04:12
Zeinab Abosedaira
Hello, I've successfully solved the problem. It turned out there was a problem in wsl, so I just shut it down from the PowerShell and restarted it again, and now it's working. It turned out it's a common problem on wsl2.
eduardopaiva and finn_amann like this.
[Other] blueCFD-Core-2016 user compiled solvers not running in parallel sbence OpenFOAM Installation 10 December 5, 2018 08:44
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 07:02
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 03:50
