July 8, 2022, 05:39 |
Some error after change time step
JD
Rep Power: 3 |
I have run buoyantPimpleFoam simulation and use:
startTime: 0 endtime: 500 deltaT: 0.01 writeInterval: 5 then simulation was run sucssefully.but after that i want to use startTime: 0 endtime: 18000 now i am facing some problem and not running simulation. please anyone have any solution then guide me. |
July 8, 2022, 07:05 |
#2 | |
Rep Power: 4 |
Can you please post your error message |
July 8, 2022, 08:35 |
JD
Rep Power: 3 |
here you can find the attachment of the log file.
July 10, 2022, 03:36 |
now error after 86.5s of simulation
JD
Rep Power: 3 |
Courant Number mean: 0.000171556 max: 5.99997
Time = 86.5055 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for Ux, Initial residual = 1.1103e-05, Final residual = 1.12525e-09, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 8.54981e-06, Final residual = 1.01351e-09, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 6.25258e-06, Final residual = 7.03431e-10, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 5.12811e-06, Final residual = 1.5651e-09, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.000918175, Final residual = 0.000918175, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.56108e-10, global = -2.96827e-11, cumulative = -1.32818e-05 DICPCG: Solving for p_rgh, Initial residual = 0.000918171, Final residual = 0.000918171, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.56106e-10, global = -2.96828e-11, cumulative = -1.32818e-05 DILUPBiCGStab: Solving for omega, Initial residual = 1.00009e-06, Final residual = 5.20401e-11, No Iterations 1 DILUPBiCGStab: Solving for k, Initial residual = 4.03133e-05, Final residual = 5.18814e-09, No Iterations 1 ExecutionTime = 32440.9 s ClockTime = 32973 s Courant Number mean: 0.00017156 max: 5.99997 Time = 86.5074 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for Ux, Initial residual = 1.11029e-05, Final residual = 1.12504e-09, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 8.55075e-06, Final residual = 1.01357e-09, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 6.25451e-06, Final residual = 7.03589e-10, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 5.12812e-06, Final residual = 1.56507e-09, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.00101466, Final residual = 0.000981534, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.80688e-10, global = -2.96528e-11, cumulative = -1.32818e-05 DICPCG: Solving for p_rgh, Initial residual = 0.000788218, Final residual = 0.000788218, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 3.05724e-10, global = -2.9683e-11, cumulative = -1.32819e-05 [58] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [58] #1 Foam::sigFpe::sigHandler(int) at ??:? [58] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [58] #3 ? in "/lib/x86_64-linux-gnu/libm.so.6" [58] #4 Foam::omegaWallFunctionFvPatchScalarField::calcula te(Foam::momentumTransportModel const&, Foam::List<double> const&, Foam::fvPatch const&, Foam::Field<double>&, Foam::Field<double>&) at ??:? [58] #5 Foam::omegaWallFunctionFvPatchScalarField::calcula teTurbulenceFields(Foam::momentumTransportModel const&, Foam::Field<double>&, Foam::Field<double>&) at ??:? [58] #6 Foam::omegaWallFunctionFvPatchScalarField::updateC oeffs() at ??:? [58] #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::updateCoeffs() at ??:? [58] #8 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::CompressibleMomentumTransportModel<Foam::dy namicTransportModel> > >, Foam::CompressibleMomentumTransportModel<Foam::dyn amicTransportModel> >::correct() at ??:? [58] #9 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam" [58] #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [58] #11 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/buoyantPimpleFoam" [cfdserver:169821] *** Process received signal *** [cfdserver:169821] Signal: Floating point exception (8) [cfdserver:169821] Signal code: (-6) [cfdserver:169821] Failing at address: 0x3e90002975d [cfdserver:169821] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f83222a3090] [cfdserver:169821] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f83222a300b] [cfdserver:169821] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f83222a3090] [cfdserver:169821] [ 3] /lib/x86_64-linux-gnu/libm.so.6(+0x7c470)[0x7f83224f4470] [cfdserver:169821] [ 4] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libmomentumTransportModels.so(_ZN4Foam35omegaWallF unctionFvPatchScalarField9calculateERKNS_22momentu mTransportModelERKNS_4ListIdEERKNS_7fvPatchERNS_5F ieldIdEESD_+0x426)[0x7f8325853ba6] [cfdserver:169821] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libmomentumTransportModels.so(_ZN4Foam35omegaWallF unctionFvPatchScalarField25calculateTurbulenceFiel dsERKNS_22momentumTransportModelERNS_5FieldIdEES6_ +0x75)[0x7f8325853655] [cfdserver:169821] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libmomentumTransportModels.so(_ZN4Foam35omegaWallF unctionFvPatchScalarField12updateCoeffsEv+0x28e)[0x7f83258546ae] [cfdserver:169821] [ 7] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libcompressibleMomentumTransportModels.so(_ZN4Foam 14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE8 Boundary12updateCoeffsEv+0x72)[0x7f832555c242] [cfdserver:169821] [ 8] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libcompressibleMomentumTransportModels.so(_ZN4Foam 9kOmegaSSTINS_13eddyViscosityINS_8RASModelINS_34Co mpressibleMomentumTransportModelINS_21dynamicTrans portModelEEEEEEES5_E7correctEv+0x36f)[0x7f8325646b3f] [cfdserver:169821] [ 9] buoyantPimpleFoam(+0x43170)[0x559044b2b170] [cfdserver:169821] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f8322284083] [cfdserver:169821] [11] buoyantPimpleFoam(+0x4627e)[0x559044b2e27e] [cfdserver:169821] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 58 with PID 0 on node cfdserver exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- [exited with status 136.] |
July 11, 2022, 01:40 |
Rep Power: 4 |
You say, you just adjusted the endtime right? Maybe start your simulation from the successfull simulation from timestep 500 to 1800. MAybe this will work out.
Beside that: Your local courant number is pretty high. Some discretization shemes need a courant number below 1 or 0.5 otherwise they become unstable. This relates to the propagation of the quantity which would otherwise become unphysical. You should check where the high courant number occurs in your mesh and consider to refine that region |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
