How to use actuationDiskSource as source instead of sink? |
July 19, 2022, 14:08 |
Max Spencer
Rep Power: 6 |
I am trying to use fvOptions actuationDiskSource to add energy to the flow stream rather than extract. The simplest example is to use the turbineSiting tutorial but change in the fvOptions line 26 of sink from 'true' to 'false'.
This results in an error saying the Cp and Ct cannot be negative. Any examples where this actuationDiskSource is not used as a sink, but a source? Thanks! |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
