January 18, 2017, 09:30 |
Dam break example results different
Vania
Rep Power: 9 |
Hi there.
I am new to OpenFOAM and started testing some examples from the tutorial. In the dam break problem my results are different from what is documented (see plots attached). I was wondering if someone has any idea why these differences are observed and if all is ok with my installation or if something is missing. Many thanks in advance for your time and help. Vānia |
June 15, 2022, 09:35 |
Re: Dam break example results different
Chris van Dijk
Rep Power: 3 |
I have the same issue as you. My results are different for one and four cores. Note that your figures look a lot like the ones in the tutorial (https://cfd.direct/openfoam/user-gui...k/#x7-520002.3), so I assume your results are right. However I don't know why the results are different, I'd also like to know the answer. Greetings, Chris |
June 16, 2022, 16:53 |
Chris van Dijk
Rep Power: 3 |
The residual values are a bit different. The average of the final residuals for the last five timesteps for 1 core are 8.264e-8, for 4 cores it's 9.267e-8. This is probably correlated with the amount of iterations needed for convergence (again as an average of the last five timesteps: 52 for 1 core, 114 for 4 cores).
However, I'd say an error of less than 1e-7 shouldn't cause such a big discrepancy between the results for 1 and 4 cores. |
August 10, 2022, 07:29 |
Chris van Dijk
Rep Power: 3 |
Hi, I managed to find the answer (together with help from my thesis supervisors) in the meantime. The problem is the tolerances. If I edit my fvSolutions file and change all tolerances to 1e-18 or so, my results for one and four cores are much more similar.
Greetings, Chris |
dam break results |
Dam break with gate lifting | Oldrich | OpenFOAM Running, Solving & CFD | 1 | November 18, 2021 10:53 |
dam break problem | sega | Main CFD Forum | 2 | April 23, 2008 11:39 |
Zhou's dam break experiment | Mary | Main CFD Forum | 1 | November 19, 2007 11:47 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Dam break // wet bed | Mehdi BEN ELHADJ | Main CFD Forum | 4 | August 24, 2000 07:39 |
