Process killed unexpectedly and without any apparent reason
Old   September 27, 2018, 08:02
Default Process killed unexpectedly and without any apparent reason
Andreas
amh@inventas.no is on a distinguished road
Dear all,
I have recently installed v1806 on windows using Docker/virtualbox from www.openfoam.com.
However, when I try to run my case the 3rd refineMesh crashes and there is no error in the log.refineMesh.3 The process simply seems to be killed for no apparent reason. I have run this succesfully without errors on an HPC using version v1712.
Do any of you know why the process kills? Anyway it does continue on with snappyHexMesh afterwords but this is also killed after running for a while whithout giving me any feedback as to why.
Running refineMesh on /home/ofuser/workingDir/Inventas_HydroLift_P42
/opt/OpenFOAM/OpenFOAM-v1806/bin/tools/RunFunctions: line 109: 10084 Killed $appRun $appArgs "$@" > $logFile 2>&1
Running topoSet on /home/ofuser/workingDir/Inventas_HydroLift_P42
/opt/OpenFOAM/OpenFOAM-v1806/bin/tools/RunFunctions: line 109: 10086 Killed $appRun $appArgs "$@" > $logFile 2>&1
[ofuser@default Inventas_HydroLift_P42]$ cd /opt/OpenFOAM/OpenFOAM-v1806/bin/tools/
amh@inventas.no is offline   Reply With Quote
Old   January 18, 2024, 11:00
Thokala Divya
divyathokala01@gmail.com is on a distinguished road
Hi could you resolve this problem. I am facing the same issue even in cluster. The simulation is killing after a time step.
Divya
divyathokala01@gmail.com is offline   Reply With Quote
Old   January 19, 2024, 02:15
Andreas
Hi Thokala. I have not used OF for several years now. I was never able to fix this issue. Maybe you should try starting a new thread?
docker, killed process, windows
