How is strength value used in the Energy Equation of XiFoam solver? |
August 7, 2020, 13:43 |
Manideep
Rep Power: 6 |
I have been working with XiFoam solver for a simulating a combustion process. I wanted to know how the strength value in Combustion properties is used exactly in the simulation. I have gone through few threads in the forums regarding this issue but could not find the answer. I am assuming that the strength value is used in the Energy equation but I do not know exactly how. If anyone has an answer, kindly do reply. Thank you in advance. |
August 7, 2020, 13:56 |
What is "strenght" here?
Energy equation used by XiFoma (EaEqn.H) is here: https://github.com/OpenFOAM/OpenFOAM...XiFoam/EaEqn.H |
August 7, 2020, 14:40 |
Manideep
Rep Power: 6 |
In the combustion properties of XiFoam solver, we need to define the ignition properties such as diameter of ignition, duration of ignition, and strength of ignition.
Beqn is written as...... bEqn = beqn + ((strength * cellVolume * rhou) / duration ) / (b[ignSite] + 0.001) Where bEqn is the flame propagation. When I try to determine the units of strength, i get s/kg I find this strength term difficult to understand? Kindly comment if anyone knows the answer. |
August 30, 2022, 02:20 |
#4 | |
Dilshan Casseer
Rep Power: 8 |
BEqn is the transport equation of regress variable 'b' in XiFoam (Weller Model). B Equation is actually fvm::ddt(rho, b) + mvConvection->fvmDiv(phi, b) + fvm::div(phiSt, b) - fvm::Sp(fvc::div(phiSt), b) - fvm::laplacian(thermophysicalTransport->alphaEff(), b) == fvModels.source(rho, b) For the exact equation, refer H. G. Weller, "Development of a New Flame Area Combsution Model Using Conditional Averaging," Department of Mechanical Engineerig, Imperial College of Science Technology and Medicine, 1993. Strength parameter is used in the ignition process, to start the reaction. At the ignition, the BEqn is modified as bEqn = beqn + ((strength * cellVolume * rhou) / duration ) / (b[ignSite] + 0.001) This sort of starts the combustion, (by injecting a value less that one to b), which then propagates as per the transport equation for b. strength, location and duration basically specifies the ignition. |
Energy equation - where is the turbulent kinetic energy? | usv001 | OpenFOAM Programming & Development | 1 | January 25, 2022 15:04 |
Porous Modeling of Energy equation in OpenFOAM | mohammad_kordo | OpenFOAM Running, Solving & CFD | 9 | November 22, 2020 07:18 |
Poisson equation in custom solver diverges for large boundary values | babakflame | OpenFOAM Running, Solving & CFD | 2 | May 23, 2017 20:11 |
modify a solver to account for energy equation. | Yanci | OpenFOAM Running, Solving & CFD | 0 | November 11, 2014 09:23 |
Wave Action Equation Solver for OpenFOAM | chyczewski | OpenFOAM Programming & Development | 7 | September 4, 2013 11:06 |
