Using MRFSimpleFoam + CyclicAMI to simulate propeller/fan |
August 30, 2022, 23:15 |
Chiu Yang Cheng
Hello All,
I hope you guys are doing great. I'm a rookie on using OpenFOAM, I'm trying to simulate a propeller/fan by using MRF in simpleFOAM. Turbulence model is SST k-omega. The case has two region, one is inner region(rotation zone), another is outer region. And the interface between two region's boundary are set as cyclicAMI. The first problem is that when I start the calculation, there will be a maximum pressure value(about 10^7N) on the surface of the propeller, and my inflow is only 2m/s, rotation speed is 12 rps. I don't know if it is the wall function or the boundary condition is set wrong, so I attach the relevant files for the case. The second problem is that when I set the rotation speed in MRFProperties as 0 rps, and there is only inflow in the flow field. I found that the fluid seems to deliberately bypass my rotation region, It's just like the fluid doesn't go into the rotation zone. It seems that there is a problem with the AMI setting. Any help is appreciated Thank you, -Jason HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 7 ( outlet { type patch; nFaces 3152; startFace 10769020; } wall1 { type wall; nFaces 26746; startFace 10772172; } inlet { type patch; nFaces 2978; startFace 10798918; } AMI_2 { type cyclicAMI; nFaces 94536; startFace 10801896; transform noOrdering; neighbourPatch AMI_1; } AMI_1 { type cyclicAMI; nFaces 137406; startFace 10896432; transform noOrdering; neighbourPatch AMI_2; } hub1 { type wall; nFaces 8680; startFace 11033838; } prop { type wall; nFaces 68770; startFace 11042518; } ) // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.5 0 0); } outlet { type zeroGradient; } wall1 { type noSlip; } hub1 { type noSlip; } prop { type noSlip; } "(AMI_1|AMI_2)" { type cyclicAMI; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } "(wall1|prop|hub1)" { type zeroGradient; } "(AMI_1|AMI_2)" { type cyclicAMI; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0459375; boundaryField { inlet { type inletOutlet; inletValue uniform 0.0459375; } outlet { type inletOutlet; inletValue uniform 0.0459375; } wall1 { type inletOutlet; inletValue uniform 0.0459375; } hub1 { type kqRWallFunction; value uniform 0; } prop { type kqRWallFunction; value uniform 0; } "(AMI_1|AMI_2)" { type cyclicAMI; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 4593.75; boundaryField { inlet { type inletOutlet; inletValue uniform 4593.75; } outlet { type inletOutlet; inletValue uniform 4593.75; } wall1 { type inletOutlet; inletValue uniform 4593.7; } prop { type omegaWallFunction; value $internalField; } hub1 { type omegaWallFunction; value $internalField; } "(AMI_1|AMI_2)" { type cyclicAMI; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } wall1 { type calculated; value uniform 0; } prop { // Mandatory entries (unmodifiable) type nutkRoughWallFunction; Ks uniform 0.0000384; Cs uniform 0.75; value uniform 0; } hub1 { // Mandatory entries (unmodifiable) type nutkRoughWallFunction; Ks uniform 0.0000384; Cs uniform 0.75; value uniform 0; } "(AMI_1|AMI_2)" { type cyclicAMI; } } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // MRF1 { cellZone rotor; active yes; // Fixed patches (by default they 'move' with the MRF zone) origin (0 0 0); axis (-1 0 0); omega 0.0; nonRotatingPatches (AMI_1 AMI_2); } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear 0.5; grad(U) cellLimited Gauss linear 1; } divSchemes { default none; div(phi,U) Gauss linearUpwindV grad(U); div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 0.5; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.5; } wallDist { method meshWave; } // ************************************************************************* // HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.05; smoother GaussSeidel; nCellsInCoarsestLevel 20; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-07; relTol 0.05; } k { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-07; relTol 0.1; } omega { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-07; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 3; pRefCell 0; pRefValue 0; } relaxationFactors { fields { p 0.2; } equations { U 0.3; k 0.3; omega 0.3; } } // ************************************************************************* // |
[snappyHexMesh] Creating mesh for cyclicAMI boundaries | otaolafr | OpenFOAM Meshing & Mesh Conversion | 3 | October 11, 2022 00:07 |
MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 10:13 |
MRFSimpleFoam Tutorial | bastil | OpenFOAM Running, Solving & CFD | 48 | August 1, 2012 10:00 |
Simulate the wind profile on a wind turbine---> HOW ???? | mohammad | Main CFD Forum | 0 | April 13, 2012 08:07 |
about MRFSimpleFoam and ggi | wllmk1 | OpenFOAM Running, Solving & CFD | 0 | February 5, 2011 04:52 |
