Can AMI work with rotating bodies not aligned with the X,Y,Z axes? |
January 2, 2023, 09:59 |
TWB
Rep Power: 19 |
I'm trying to simulate the flow past an elevator, wing and fuselage. The fuselage' length is along the x axis and the wing span is along the z axis. Hence drag and lift are along the x and y directions. The elevator is orientated at 45deg to the z axis and it's pointing down. I would like to rotate the elevator using AMI. The examples I have seen always have the AMI rotation aligned along the main x,y or z axis. I tried to run my case but the patch weights of one side of the AMI always decreases to a low value and my solution diverges. Hence, I wonder if the problem lies with my setup or that AMI doesn't work if the rotation is not aligned with x,y or z. Can someone enlighten me? Thanks! |
January 26, 2023, 09:12 |
TWB
Rep Power: 19 |
Just an update. I tried to run 2 cases:
1. elevator rotating aligned with the z axis 2. elevator rotating aligned 45deg wrt z axis. Both results completed in 1s. The 2nd case patch weights of one side of the AMI decreases to zero, but the 1st case doesn't. However, with the: lowWeightCorrection 0.2; the simulation doesn't abort and runs till the end. Force results looks reasonable too. Of course, different cases may give diff results. But at least this shows tt AMI problem doesn't have to align with the axis. But the patch weights may get low and cause divergence at times. |
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found | cdase | ANSYS Meshing & Geometry | 0 | August 26, 2018 14:31 |
Translating and Rotating AMI | HiddenSquid | OpenFOAM Pre-Processing | 1 | October 25, 2017 03:59 |
Rotating Mesh, errors in Cyclic AMI interface | WhiteW | OpenFOAM | 2 | September 26, 2016 09:12 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Y+ on rotating bodies | Luiz Eduardo Bittencourt Sampaio | Main CFD Forum | 4 | July 13, 2001 10:55 |
