January 8, 2023, 05:33 |
Euler-Euler approach - multiphase problem
Guilherme
Rep Power: 10 |
Is it possible to model a multiphase problem (more than two phases) with an Euler-Euler approach in OpenFOAM? What is the solver?
I left an example of the problem I'm studying. **Is there any DES solver in OpenFOAM for multiphase problems? |
January 20, 2023, 15:33 |
Guilherme
Rep Power: 10 |
Can anyone help me?
January 23, 2023, 03:18 |
Rep Power: 5 |
Hey
I am not sure about DES, but multiphaseEulerFoam does what its name suggests, you should check it out. If you have only two phases, there is also a variant twoPhaseEulerFoam in the tutorials. Once you have your setup up and running you can maybe try to swap the turbulence model and see if it accepts DES models. Good luck! |
euler-euler, multiphase, openfoam 7 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
How to assign material to porous region in multiphase problem | mataus | Fluent Multiphase | 0 | December 12, 2019 07:03 |
Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem) | jessie | FLUENT | 3 | May 29, 2014 11:05 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 07:59 |
steady and unsteady Euler eq problem | AO | Main CFD Forum | 3 | January 27, 2004 16:29 |
