[Sponsors] | |||||
icoUncoupledKinematicParcelFoam causes a paraview error |
Turhan
Rep Power: 5 ![]() |
Dear all,
I am trying to add sediment to a pipeline with water for a simulation. As starters, I chose to use icoUncoupledKinematicParcelFoam. However every simulation I ran got the same error when I tried to visualise the simulation in paraview. The error happens when I open paraview and load the .foam file. It would close paraview and show the error "The label type is not set!" in the terminal. To compare results, I tried simulating the tutorial of icoUncoupledKinematicParcelFoam called hopper. But when I tried to visualise this in paraview it still gave the exact same error. There has been only one way where I could prevent this error, and that is by opening paraview, and before applying the .foam file I go to "Mesh Region" and uncheck "Lagrangian/KinematicCloud", then paraview can visualise the simulation without an error. Sadly this means that I do not see the sediment as well. I was wondering why this error is occurring to me and how I could solve this. |
| Tags |
| icouncoupledparcelfoam, lagrangain, lagrange, paraview |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 19:11 |
| [blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
| DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
| ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
| Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
