Pressure won't converge using SimpleFoam
Old   June 14, 2021, 07:02
Default Pressure won't converge using SimpleFoam
Richard97 is on a distinguished road
Hi All,
I'm running a case in simpleFoam and my pressure residuals won't converge. A similar case to this run a number of years ago had converged at this stage.
I have checked the mesh, and there are no issues with skewness or nonOrthogonality so I know the error doesn't lie there.
my fvScheme and fvSolution are as follows
fvSolution
solvers
p
solver GAMG;
tolerance 1e-6;
relTol 0.1;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
U
solver smoothSolver;
tolerance 1e-6;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-6;
relTol 0.1;
nSweeps 1;
epsilon
tolerance 1e-6;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-3;
U 1e-4;
"(k|epsilon)" 1e-4;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
cache
grad(U);
fvScheme
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
div(phi,epsilon) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited corrected 0.333;
interpolationSchemes
default linear;
snGradSchemes
default limited corrected 0.333;
fluxRequired
default no;
p;
If anyone could advise, that would be greatly appreciated
Richard97 is offline   Reply With Quote
Old   June 14, 2021, 07:05
This is the most recent time step of the output
smoothSolver: Solving for Ux, Initial residual = 6.26867549999e-05, Final residual = 4.83802208018e-06, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 4.91362392681e-05, Final residual = 3.40070029735e-06, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.000164303461286, Final residual = 9.92105112991e-06, No Iterations 4
GAMG: Solving for p, Initial residual = 0.00202976194843, Final residual = 0.000165595182502, No Iterations 2
time step continuity errors : sum local = 8.95914605453e-09, global = 2.94382119613e-10, cumulative = -2.68013954291e-06
smoothSolver: Solving for epsilon, Initial residual = 0.000134760412047, Final residual = 7.63620479172e-06, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.000571158570201, Final residual = 3.84860947038e-05, No Iterations 4
ExecutionTime = 88904.63 s ClockTime = 90881 s
Old   June 15, 2021, 07:13
Tobermory will become famous soon enough
Some suggestions:
- Check your boundary conditions. Are they identical to the previous set up? Has OF changed in its treatment of those boundary types since you last ran the case?
- do you get the same problem if you change the pressure solver from GAMG to PCG?
- How good is your mesh quality?
Maybe also look at the pressure field in paraview to see if there is a bump/discontinuity/irregularity in the pressure field - that might help you identify where the solution is stalling, and therefore help find the reason.
Good luck & let us know when you find the solution!
Tobermory is offline   Reply With Quote
Old   June 15, 2021, 07:31
Daniel
DevilX is on a distinguished road
Hey Richard,
I think here lies the problem:
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
At first, 0.3 in fields for p is low, try a higher one. Your residuals look good, so this hould help. Also put a factor in Equations for p in, like this:
relaxationFactors
fields
p 0.7;
equations
U 0.7;
k 0.7;
p 0.7;
epsilon 0.7;
DevilX is offline   Reply With Quote
Old   June 24, 2022, 08:28
geth03 is on a distinguished road
Originally Posted by DevilX View Post
Hey Richard,
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
relaxationFactors
fields
p 0.7;
equations
U 0.7;
k 0.7;
p 0.7;
epsilon 0.7;
1. how do you know that p-field URF is too low? there is no general rule to that, but the industry standard is 0.3. the better value might be problem dependent, but how will you know that?
2. it is the first time i hear that p-Eqn should be underrelaxed. where did you get that one?
geth03 is offline   Reply With Quote
Old   June 24, 2022, 11:17
Domenico Lahaye
dlahaye is on a distinguished road
For relaxation, see e.g. https://en.wikipedia.org/wiki/SIMPLE_algorithm and references cited.
dlahaye is offline   Reply With Quote
Old   July 4, 2022, 05:17
this is not a good reference when you consider how the simple algorithm is constructed in openfoam. the implementation is different from what the sources suggest.
URF for p-equation in OF will violate the mass conservation, so only the p-Field should be underrelaxed.
p_field_URF + U_eqn_URF = 1, this is a good rule.
@Richard97
stalling residuals are not telling if a solution is converging or not, i know that this behaviour is annoying. you should place samplePoints in your domain and track the iteration behaviour of those points. if they are not changing much, probably your problem is converged, considering your flow physics and numerics.
Old   February 22, 2023, 00:50
Default My p_rgh is not converging when using temperature
stoic
puneesh is on a distinguished road
Hi all,
I am having a similar issue with pressure(p_rgh). I ran a simplefoam case without temperature, only for flow, and it converged. Then using that case I created buyoantboussinesqsimplefoam case for temperature but my p_rgh is not converging. My flow is incompressible.
puneesh is offline   Reply With Quote
convergence, pressure, simple foam
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
Pressure Inlet Boundary Conditions Mr.Goodcat FLUENT 5 June 20, 2019 01:47
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 06:50
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 11:59
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
