simpleFoam convergence error
Old   May 23, 2023, 03:13
Default simpleFoam convergence error
jinhoon park
tusin111 is on a distinguished road
hello! I'm new to using openFoam!
I have one question for you.
In the figure, convergence occurs when the cylinder at the top is used as the entrance and the speed is given downward.
however
If the cylinder on the top side is used as the same entrance and the air is released by speeding upward, convergence will not occur.
Do I need to modify the initial conditions or anything else in this process??
tusin111 is offline   Reply With Quote
Old   May 23, 2023, 07:52
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
Hi.
Try setting the initial velocity within the fluid either the up or down direction, according to the problem.. this should aid convergence. If it still crashes, try checking your outflow boundaries, as well as gravity terms, if they matter for you problem... if it still crashes, then you have a mesh issue...
good luck!
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   May 23, 2023, 21:45
jinhoon park
Originally Posted by calim_cfd View Post
Hi.
good luck!
thank you for the reply
Now my U and P are in the same condition as the picture
Solved with kOmegaSST. but can't converge
I never considered the gravitational term. How do I check the gravity term?
It is currently in its initial state
There are U, P, nut, k, and omega.
Old   May 24, 2023, 22:43
jinhoon park
Hi.
good luck!
I have one question!!!
I converged
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
residualControl
p 1e-4;
U 1e-4;
"(k|omega)" 1e-4;
relaxationFactors
equations
U 0.001;
k 0.004;
omega 0.005;
Relaxation coefficients higher than that did not converge until 1.e-4.
What are the problems with using very small relaxation coefficients?
Or is it okay to interpret it this way?
Old   May 26, 2023, 16:02
calim_cfd's Avatar
mauricio
I converged
SIMPLE
consistent yes;
residualControl
p 1e-4;
U 1e-4;
"(k|omega)" 1e-4;
relaxationFactors
equations
U 0.001;
k 0.004;
omega 0.005;
You seem a bit lost overall... to relax your solution this much usually indicates a problem or a potential one.... but sometimes this is allowed... but lowering all factors is danger because you may "finish you simulation" but it might not have converged to the actual solution because you damped the solution so much that it eventually stopped and thus you get an intermediate result.... to see this.. check the solution data and see whether the problem actually ended.
regards,
Best Regards
/calim
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
