Why is the 'lagrangian' folder not output for small particle size? |
July 21, 2023, 14:05 |
Fanchao Meng
I successfully simulated particle transport using the reactingParcelFoam solver in OpenFOAM v1912. The parcels were injected using the manual injection method, and each parcel contained only one particle. The particle size (diameter) was fixed at 1e-6 m.
However, when I attempted to change the particle size to be lower or equal to 0.7e-6 m, the 'lagrangian' folder disappeared. This folder contains important information for each particle, such as particle ID, position, velocity, temperature, etc. Does anyone know how to configure the simulation to output the 'lagrangian' folder even for small particle sizes? Any assistance would be greatly appreciated. |
August 3, 2023, 04:26 |
Are you sure that your particles are still in the domain at write time? Maybe they just evaporated or fell below a limit, e.g. for minParcelMass. You can try to change or add the latter in your cloud's constantProperties. It might be set to 1e-15 as a default, which could be in the range of your particles' mass.
lagrangian, reactingparcelfoam, small particle |
output lagrangian particle volume fraction "reactingParcelFoam" | bijan darbari | OpenFOAM Programming & Development | 20 | February 12, 2022 22:15 |
Assign Particle Size in java for Polyhedral Partcles | Vee | STAR-CCM+ | 1 | April 22, 2018 09:45 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
Request for Lagrangian Particle Tracking Validation or Verification Paper | Mojtaba.a | OpenFOAM Verification & Validation | 6 | May 23, 2016 01:47 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
