"error while loading shared libraries" error when running simpleFoam in parallel
Prev Previous Post   Next Post Next
Old   August 1, 2023, 15:19
Default "error while loading shared libraries" error when running simpleFoam in parallel
Tim
timdrake is on a distinguished road
I am putting together a cluster of 20 physical computers, each containing 4 cores. Right now I am trying to get the master and the first node (acl-n1) working. I am using MPI and NFS.
From my understanding, the openfoam9 dir should be in my shared folder OpenFOAM. I have updated the bashrc in openfoam9/etc/bashrc to correspond with the new dir.
Some context info:
$PATH
/home/mpiuser/.local/bin:/path/to/openmpi/bin:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/bin:/opt/paraviewopenfoam56/bin:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/cmake-*/bin:/home/mpiuser/OpenFOAM/mpiuser-9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/site/9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/openfoam9/bin:/home/mpiuser/OpenFOAM/openfoam9/wmake:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
$LD_LIBRARY_PATH
/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/paraview-5.6:/opt/paraviewopenfoam56/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/mpiuser/OpenFOAM/mpiuser-9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/site/9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64GccDPInt32/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/dummy
Shared folder that is mounted correctly on acl-n1: /home/mpiuser/OpenFOAM
$FOAM_INST_DIR=/home/mpiuser/OpenFOAM
$FOAM_RUN=$FOAM_INST_DIR/mpiuser-9/run
$machines is:
master
acl-n1
I copied the tutorials dir to $FOAM_RUN, and im trying to run the airFoil2D case:
mpirun --hostfile $machines -np 5 simpleFoam >> log
this is the output when ran:
mpirun was unable to find the specified executable file, and therefore
did not launch the job.  This error was first reported for process
rank 4; it may have occurred for other processes as well.
NOTE: A common cause for this error is misspelling a mpirun command
      line parameter option (remember that mpirun interprets the first
      unrecognized command line token as the executable).
Node:       acl-n1
Executable: /home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam
Why is this wrong if it is shared in the NFS??
If I specify where simpleFoam is exactly:
mpirun --hostfile $machines -np 5 $FOAM_INST_DIR/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam >> log
then it gives a new error:
/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam: error while loading shared libraries: libPstream.so: cannot open shared object file: No such file or directory
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[49322,1],4]
  Exit code:    127
Why cant it find the library? simpleFoam can run just fine on each computer when there are 4 processes, but when i try 5 it doesnt work, no matter what computer i run it from.
Please help, I have been tearing out my hair for weeks on this!!
timdrake is offline   Reply With Quote
mpi, nfs, openfoam9, parallel, shared libraries
Issues Running in Parallel on SLURM HPC jd01930 OpenFOAM Running, Solving & CFD 0 November 30, 2022 17:12
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
Identifying Markers in a CGNS Mesh tjim SU2 3 October 12, 2018 01:21
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
